Gear stuck and AC, stereo, and windows not working
Hi!
I just bought a used 2001 Lexus GS300 last week. Everything was working great so far.
Except that today, when I got into the car and rolled my windows down and then tried to roll them back up, they got stuck. What's more is that the gear is stuck in park, and the AC and stereo also don't work.
There doesn't seem to be any one fuse that affects all these (maybe I'm wrong), and I couldn't find too much information about the relays in the manual.
I was able to close my windows by holding the key in the door in the lock position for a few seconds, as per the manual.
Has anyone had such an issue with their Lexus or Toyota?
HELP!
UPDATE: Also noticed that the "BRAKE" dashboard light is on.
HELP!
So there can be a problem with the battery even though the car starts fine? Also, I was able to drive the car around after manually overriding the shift.
Yes their can, this is the most sensitive car when it comes to electronics and the battery I've ever owned in my life, I have to replace my battery every two years cause of sitting outside in winters, it's my daily, go grab a new POSITIVE battery terminal at advanced auto and see if that works for u..
Greatdav (01-01-22)
I had the guys at an Autozone check the terminals, and they say it looks good. I'll get a new one anyway if you say so, but I have an update that I'd like your opinion on first.
So after driving the car, there's a lot more stuff that's not working. The speedometer and the power steering, for example. This makes me think maybe there's a computer failure? All these things are computer assisted, right? Or if not the computer, then at least some kind of circuitry. Thoughts?
ECUs are relatively expensive. I would at least try the battery first. Especially if yours is over 2 years old. Like thye said, these cars are sensitive to battery issues. Just because it cranks the car doesn't mention it can't cause other issues.
Greatdav (01-01-22)
Got it fixed today. It was the ECU! It wasn't getting any power. Luckily I found a nice mechanic, so he actually diagnosed it and found a shorted wire. Cost a mere $150 to fix.
Greatdav (01-01-22)
Hi!
HELP!
HELP!
Old thread from April 2014. But do like he did. Take the car in for a diagnosis if you dont know how to voltage/ohm check the pcm.
