rear main seal
Old Feb 11, 2014 | 04:07 PM
Acer's Avatar
Acer
Default rear main seal
I tried to search but to no help. I removed the old rear main seal (first time for me) but I'm having trouble installing the new one.
I tried tapping it to go in evenly but it keeps coming out.Then I tried again and it went in to far and isn't flushed against the pulley (don't know the name of it) I had to remove again and ended up tearing it because I had no seal puller.So I'll have to buy another one and hopefully it will go in smoother this time.Also do you use any type of sealant or grease on the seal? What about the flex plate bolts.Do I use redtite? Thanks
Old Feb 11, 2014 | 04:50 PM
burny's Avatar
burny
There is a ton of you tube stuff out there
Old Feb 11, 2014 | 04:59 PM
Acer's Avatar
Acer
I saw that and a few others, but the seal carrier is still on the block.I don't want to remove it if I don't have too.
Old Feb 11, 2014 | 05:09 PM
burny's Avatar
burny
when I googled it, I saw several clublexus threads on there about rear mains. I have not done one so can't really answer.
Old Feb 11, 2014 | 05:13 PM
Acer's Avatar
Acer
Have you looked at them?probably not because none of them answer my questions.I did search.
Old Feb 12, 2014 | 11:15 AM
Acer's Avatar
Acer
anyone?....
Old Feb 12, 2014 | 12:48 PM
SC4Paulo's Avatar
SC4Paulo
Remove the seal carrier and call it a day. If you don't remove that carrier you won't get the seal seated properly to seal and totally defeats the purpose of replacing the rear main seal.
Old Feb 12, 2014 | 02:23 PM
Acer's Avatar
Acer
If I remove it is there a gasket I need to replace?
Louielace6
Nov 5, 2018 06:28 AM
lexslexus
Feb 27, 2018 07:24 PM
Lexus082
Mar 17, 2011 08:23 PM
tritron
Jul 24, 2009 05:25 PM
[ant]
Feb 17, 2009 08:58 AM
