Tire help asap
Old 07-16-13, 07:59 PM
spacecoupe
spacecoupe's Avatar
Default Tire help asap
So I got used 18' rims with tires. The tires are in poor shape 235/45/18. My friend works at BMW and gave me two tires for the rear 255/35/18 and 2 tires for the front 225/40/18. Will the car drive ok since they are on separate axles? Any advice is a great help
Old 07-16-13, 08:06 PM
Mr Jokster
Mr Jokster's Avatar
Why would you put wider tires in the front?
Old 07-16-13, 08:17 PM
spacecoupe
spacecoupe's Avatar
Default Tires
Sorry got it backwards
Old 07-17-13, 09:24 AM
Debonair
iModerate
Debonair's Avatar
Yes, the car will drive fine. 2WD cars/trucks don't need matched tire sizes front to back. That said the difference in diameter of the two tire sizes he gave you is about .1 of an inch, a negligible difference.
These newer tires are 1.3 inches shorter then the tire you are taking off. You probably will not be able to see the difference though.
Old 07-17-13, 08:43 PM
spacecoupe
spacecoupe's Avatar
Default Tires
So the weight load of the vehicle should hold up fine going from 45 series to 35 and 40 series? AlsoI shouldn't have a problem with the speedometer or the abs light for that matter? Thanks for your response I'm trying not to spend $600 on tires if I don't have to.
Old 07-22-13, 07:16 PM
spacecoupe
spacecoupe's Avatar
Default Tires
thanks for your help
Scnoob
08-19-13 01:25 PM
mazis35010
09-07-11 02:00 PM
ERC66
Hybrid Technology
02-25-10 04:42 PM
jdub34
09-17-07 07:57 PM
Quick Reply: Tire help asap
