Driver's Side Door Problem?
Old Dec 13, 2002 | 04:45 AM
blkvette's Avatar
blkvette
Question Driver's Side Door Problem?
I've got a strange problem with my 98 GS300. Usually when you open the driver's door the dome light illuminates. This does not happen. Also, the dome light feature seems to work fine on the other doors. Relay problem only associated with the driver's door? I'm not sure if this is linked to another problem I am having with the factory alarm. If you have the headlights on auto and arm the vehicle the head lights should go off after 30 seconds, but don't. Two separate problems or are they related?
Old Dec 13, 2002 | 04:55 AM
GS400_PUSHER's Avatar
GS400_PUSHER
Its sounds like something is telling the Alarm system that something is open. I would check every door switch. Also try and hit the alarm set button twice when you leave your lights on and they should go off right away.
Old Dec 13, 2002 | 08:51 AM
kevs's Avatar
kevs
Check with your dealership and give them your VIN. I think this was one of the recalls on the GS.
Old Dec 13, 2002 | 01:48 PM
gs4to4's Avatar
gs4to4
"Kevs" is right. We discussed this topic a few weeks ago and member "VVTI" gave us all the info with his reply. Sounds like you need new door actuators. Do a search and give the dealer the info so you can get the repairs for free.
Let us know how everything turns out.
Old Dec 13, 2002 | 03:21 PM
GSquicksilver's Avatar
GSquicksilver
guys,
i have this problem with my rear passenger doors. so you guys serious that this is a recall? i sure hope it is.
Old Dec 13, 2002 | 04:17 PM
duster's Avatar
duster
Finally got this fixed with new actuators/pins on my '98 GS 300. Dome light would sometimes/sometimes not go on when I opened the door. Dealer couldn't duplicate the prob.
Also had the problem with the lights not going off when alarm armed. Funny thing though, the alarm would still arm indicating there was nothing "open".
Dealer indicated that based on my VIN the recall/TSB or whatever it was didn't apply.
Another funny thing was that when I was at the dealer the tech and I cruised through all the TSB/recall info on his computer and we couldn't find the door actuator/door pin one. He had to check with his service manager to get the info.
Finally, I also had the settings changed so my lights would go off when I opened the driver's side door. Not as safe as before, but better than not notcing the lights didn't shut off and end up stranded with a drained battery.
Old Dec 13, 2002 | 05:40 PM
blkvette's Avatar
blkvette
So it was covered under warranty/recall? If so, do you have the recall tag ID so I can reference that when I take my GS3 in? If not, how much was it to repair? Thanks!
Old Dec 13, 2002 | 06:36 PM
duster's Avatar
duster
Prior to my warranty expiring I complained of this issue and kept the documentation. Later, when they fixed it, I didn't have to pay. Not sure if it was categorized as warranty or goodwill.
I don't have any recall ID info or anything else to help you. Sorry. The service manager knew about it because he has a GS400.
Old Dec 13, 2002 | 06:49 PM
VVT-i's Avatar
VVT-i
The recall only effect an early production 2nd gen GS. I think time frame wise is around 10/97 to 5/98 production date. If your vehicle is late 98 or 99+ then the recall won't be effective.
Old Dec 13, 2002 | 07:51 PM
blkvette's Avatar
blkvette
Do you have the recall info as mine is a 98? Thanks!
Old Dec 13, 2002 | 07:55 PM
GSquicksilver
guys,
i just called lexus corporate and they confirmed to me that there was no such recall for the door actuators. i'm assuming you guys still have your cars under 50K miles, so probably that's why they fixed it for you.
Old Dec 14, 2002 | 12:06 AM
duster's Avatar
duster
It may not be a recall, but for sure there is some type of written advisory for this issue. Call the sevice manager at Lexus of Glendale in Calif if you have to.
ChasFenwick
Sep 17, 2022 03:48 PM
rich001
13
May 6, 2013 07:28 AM
jdmmk3
Jan 22, 2012 06:25 PM
TroySC300
Apr 15, 2008 01:22 PM
KevinLe
May 14, 2004 02:46 AM
