Door won't stay closed/locked
Old 01-15-13, 06:14 AM
duckJAI
duckJAI's Avatar
Default Door won't stay closed/locked
I'm having this problem where when I close the rear passenger door, it just bounces back and doesn't close or stay locked. The lock mechanism is "open" so that's not the problem. It can shut so it's flush to the body, but once I release pressure it doesn't stay shut or lock.
I tried to manually lock it, and use the automatic locks while applying pressure and nothing works.
Had to miss work today because if I drove off, the door would swing open on a turn.
When I use the automatic locks while applying pressure to the door, it makes a "buzzing" sound.
I thought it was because the lock mechanism was frozen but I already de-iced it and WD40'ed it with no success.
Is this the infamous door actuator problem? From what I read you can still manually lock the doors though so I'm unsure.
Any ideas/help?
Thanks!
Old 01-15-13, 06:27 AM
LuxuryGS3
LuxuryGS3's Avatar
Any ideas/help?
Thanks!
No that's not the door actuator problem. That's something entirely different, never heard of it before though or encountered it myself. Someone should be able to chime in on what to check though.
Old 01-15-13, 12:13 PM
chicov8
chicov8's Avatar
its definitly not door lock actuator (sounds more like the door closing mechanism is in open position like when you pull door handle)
Twister773
09-22-12 01:03 PM
markaus
RX - 1st Gen (1999-2003)
11-14-11 10:48 PM
bigblack06
10-14-11 09:56 AM
Lexus400mn
SC- 1st Gen (1992-2000)
07-07-07 08:17 AM
Quick Reply: Door won't stay closed/locked
