SRT Intake question.
Old Jun 25, 2012 | 11:25 PM
818GS's Avatar
818GS
Default SRT Intake question.
I want to know if you can install a SRT intake without the ecu? I keep getting mixed answers. Half say it will work and half say it won't. Will it work?And if it works will it harm the car? Thanks in advance
Old Jun 25, 2012 | 11:45 PM
clos430's Avatar
clos430
You can! But then you have to worry bout the check engine light coming on. The reason for the ecu is to adjust A/F ratio, more air intake = more fuel intake if you only have one the light will come on. Just save your money bro and buy it new
Old Jun 26, 2012 | 01:14 AM
818GS's Avatar
818GS
will it damage the car?
Old Jul 1, 2012 | 11:34 AM
818GS's Avatar
818GS
Anyone?.....
Old Jul 1, 2012 | 12:47 PM
SorrGwa's Avatar
SorrGwa
gs300, gs400, gs430?
gs430: went thru smog check, no problems, just reset ecu every 2 weeks. its a fighting ecu thing, after about 2 weeks, the ecu will relearn itself trying to readapt to the stock settings even with the piggy back.
you need the ecu, otherwise the maf sensor will recognize too much air volume, ull probably get a CEL on if you dont use the ecu.
Old Jul 1, 2012 | 12:54 PM
FinLIFE's Avatar
FinLIFE
I tried running mine with no ecu and it didnt run well at all. I had to keep my foot on the throttle just to keep it running and it ran very unevenly. Exhaust sounded and smelled different too. I wouldnt do it unless you got another way of tuning it. Mine was on a 01 gs430.
Old Jul 2, 2012 | 12:07 AM
clos430's Avatar
clos430
With time maybe, but why risk it ? IMHO do it right the first time, be patient and buy both the ecu and intake
Old Jul 8, 2012 | 02:20 PM
deeweezygs's Avatar
deeweezygs
the instructions for srt intake clearly say DO NOT USE ONE PIECE WITHOUT THE OTHER
cant use the ecu without the intake and you cant use the intake without the ecu
may damage car
it being a lexus i wouldnt chance it.....its not a honda and easy to fix and parts cheap
Old Jul 8, 2012 | 02:58 PM
bigwes's Avatar
bigwes
I have a K&N and I thought I wouldn't have to tune it cuz it said that u didn't need to. But I have a check engine light on. Now imma have to get it tuned. :/
Old Jul 9, 2012 | 06:15 AM
jd8450's Avatar
jd8450
Default Do you have to cut OE harness
I have a question do you have to cut the OE wire harness to install the intake? If so is there some where I can get a harness extention so I dont have to cut the original harness?
Thanks
JD
feras430
Performance
Oct 29, 2009 07:57 PM
sexygamja
Performance
Feb 20, 2008 07:54 PM
TwentyTen
Performance
21
Jan 20, 2005 02:35 AM
FutureGS400
Performance
Jan 29, 2004 07:57 AM
