Hot Gs4
Anybody have heat comming from under the dash while driving ? I usually wear shorts and notice there is a decent amount of heat comming from under the dash plus I drive pretty aggressive. Is this normal ? Thanks for any responses !
it doesn't blow hot air just seems like it is comming from there. Is there a firewall hole anywhere near there ? Or maybe normal heat from engine ?
I have noticed that same phenomenon come and go in my GS. There was actually a thread here last month discussing just that. I've tried fiddling with the Recirc/Fresh air, before/after turning the A/C on/off, all sorts of combination but when it's there, can't get rid of it until you turn on the A/C. Then, the hot air disappears completely and instantly. The feeling is more of a radiant heat rather than a forced air emanating just below the steering wheel at the same level as the stereo. I thought it was the stereo or the NAV but the stereo/NAV couldn't be that hot!! I was driving one cold night with the windows open and I could feel the heat from the front enveloping my lower torso. The vent was at recirculate mode and set to blow air only through the top air vents. Just to experiment, I turned on just the fan, A/C compressor off, and felt room temp air blowing from the vent but still, the feeling of hot air in front of me. I changed to fresh air mode but the heat still kept its presence even as the vents pumped cold air from the outside. The heat only stopped as soon as the A/C switch was turned on. Even with the A/C at 75 degrees setting, the heat disappeared that cold night. Cold night is 65 degrees outside.
I think I have seen the solution to this weird issue. When you feel that "heat" as you are driving, try doing this because it seemed to work for me and I was able to duplicate it several times. Turn on the A/C, and then manually turn off the A/C compressor with fan still blowing, and then turn off the fan. It has to be in that order.
Originally posted by mrsypher
Whistles, are you sure it isn't the other way around???
Originally posted by alexus
you can adjust it and poitn air some other direction or close this vent at all
oldwino
Mar 12, 2018 06:55 PM
ancdmd
Dec 17, 2011 11:14 AM
mehsoarer
IS - 1st Gen (2001-2005)
Apr 18, 2010 10:28 PM
