Opinions on balljoints
Thinking about changing both lower ball joints does anyone know if beck arnley ones are any good or should I just stick too o e m from Sewell.....just trying to save a buck and want to know if the beck arnley are sufficient $
Just to be honest, I don't even trust the OEM after doing all of the reading, viewing pictures, and reading recall notices. Remember it IS the OEM that are breaking very fast. I'm actually going to go with Moog when I change mine out because it's cheaper. I refuse to buy OEM and it's known that OEM GS balljoints are not made efficiently. My OEM infiniti balljoint was replaced at 200k...it still wasn't broken. The nut did have "joystick" play in it, but I highly doubt the OEM lexus gs balljoint will last that long.
Stop spreading Rumors..What readings? What recall notices? Ball joints ON ANY car should be replaced at certain mileage..The GS ones wear out quicker, which the more reason for proper maintenance and inspection when time is do. Go with Your Moog if it makes you fell better and sleep at night.
We do agree that proper maintenance is key. I'm looking forward to going to my friend shop this weekend to put it on a lift so I can examine the bottom of the car.
To the OP, you can go with OEM or an aftermarket ball joint. Just use a trusted brand. I've used OEM and aftermarket ball joints in the past with no problems.
so now we are talking about first gen? Mmmm..I read the sticky back in 09. stay on topic..
I have many miles on my OEM replacements, without a problem.
Besides the fact, that we all know that the 2nd gen GS ball joints should be inspected/replaced why do you say your Moog is better than OEM as a replacement? Can you Prove the OEM replacement is the same quality as the Production unit that came with your car 6-13 years ago?
Beck and Arnley is a distributor. They don't really manufacture anything on their own so what you buy from B&A could end up being OEM parts or aftermarket. I know for a fact that their coolant temperature sensor is identical to the OEM part, but when it comes to ball joints, they may be from a different supplier. I don't know anyone who uses B&A balljoints, but in any case, you should keep an eye on them. I have OEM balljoints, but even then I inspect them periodically.
Rumors!? The first Gen had recalls on their OEM ball joints, and the build quality didn't get any better with the 2nd Gen. Multiple members on CL even stated that they should've extended the recall on the 2nd Gen because of the problems. These are facts buddy. What readings...ummm on this site.
