Having the hardest time...
Old May 12, 2011 | 07:38 AM
4eign's Avatar
4eign
Angry Having the hardest time...
finding Urethane or 100% PolyUrethane bodykits for our cars...can any one help me? JP was the only one (that i like) that makes urethane but they have very limited selection. Lextacy has a nice one that am really digging but its FTP (or summthn like that) which pratically fiberglass. My bodyshop guy advises tostay away frm anything other that urethane.
Any help would be great since my car is in the shop now for 2 weeks and would like it done at the same time.
thanks in advance.
Old May 12, 2011 | 09:15 AM
veritek's Avatar
veritek
Only kit I know that is Urethane is Rod Millen, and Tom's, maybe Prussian Blue. I bought the Rod Millen front bumper from my buddy Don, who bought the Tom's front bumper, and so I've seen both first hand and they are urethane, not fiberglass.
Old May 12, 2011 | 09:17 AM
veritek's Avatar
veritek
btw, there are very few urethane kits out there, hence the reason you are having a hard time finding one, and they won't be cheap, so your choice will be very limited.
Old May 12, 2011 | 10:05 AM
speedaddic's Avatar
speedaddic
and the rod millen doesn't fit well...
Old May 12, 2011 | 10:08 AM
JeffTsai's Avatar
JeffTsai
The Tom's front bumper is fiberglass. I've installed two before.
As for why they are not many urethane kits out there. It requires a MUCH more expensive plastic injection mold to make urethane bumper and such. Fiberglass is for production at a much smaller scale.
Say for example, it costs $5000 for a fiberglass mold of a bumper. It takes longer to to lay down the fiberglass and then vacuum bag it. So this is ideal for lower production numbers. It might take anywhere up to a few hours to make a fiberglass bumper. Then after the vacuum bagging, the material needs to be gel coated, adding more time.
Now, for a urethane bumper, that mold might cost anywhere in the range of $50,000-100,000+ or more. However, it is very easy for them to crank out bumpers when they have a plastic injection mold. They pretty much just set the mold in place, have a special plastic injection pump that fills the mold, then open it up and they have a bumper. They can probably crank out a bumper every 5 minutes or so.
So, it comes down to how many bumpers the body kit manufacturer is planning to make. If they do a plastic injection mold, they can spend over $100k or or more and that's just simply not worth or is too risky it to them when they don't know how many will sell.
OEM bumpers are polyurethane and made by plastic injection molding, but they make hundreds of thousands of cars so it is worth it to them. Not to mention at those numbers it's far cheaper to make polyurethane bumpers. The aftermarket manufactures that make OEM style bumpers also use urethane because they expect to sell much more than what a modified body kit maker will expect to sell.
Old May 12, 2011 | 10:16 AM
1sWt2GS's Avatar
1sWt2GS
^ good information!
Old May 12, 2011 | 04:36 PM
TYPEII's Avatar
TYPEII
Like others have said, urethane kits are hard to come by. I mixed and matched my kit when I did my setup; L-Sportline Front, L-Tuned sides and Rod Millen rear. Out of the 3, only the Rod Millen is findable these days, the other 2 have been discontinued...
Old May 13, 2011 | 08:33 AM
4eign's Avatar
4eign
this is some VERY usefull info.
Lextacy has a nice kit that i really like http://www.lextasy.com/executive_lexus_gs300.htm
but frm my research it seems like you can get cheap FG kits or better ones that dont crack easy. Has anyone ever delt or knows someone who has with them or this kit? if so are they anygood?
as always your help is always appreciated!
Old May 13, 2011 | 12:46 PM
sakataj's Avatar
sakataj
they are findable just have to patient....took me about a year to find the l-tune sides and another year for my l-sportline rear but IMHO with the TTE lip this is the BEST setup for our gs
now all 3 are discontinued but still float around from time to time....
Old May 13, 2011 | 01:07 PM
vwynn's Avatar
vwynn
i have Lsportlines that is on the marketplace
Old May 13, 2011 | 01:10 PM
dejavu157's Avatar
dejavu157
^^ TTE lips are the truly the best!
Old May 13, 2011 | 01:12 PM
gsthree's Avatar
gsthree
I have l-sportline love the kit but it's not "VIP"... wish there was a way to find the company that use to make that kit for Dazz
Old May 13, 2011 | 01:42 PM
sakataj's Avatar
sakataj
just noticed this.....stay away from lextasy if u know whats good for you, if not search on here and find out why i say that
when did ANYONE mention VIP? OP didnt ask for a VIP kit.BTW the JP kit he mentions isn't even junction produce it is JP USA or something like that. Junction Produce doesn't make a urethane kit that im aware
Old May 13, 2011 | 02:24 PM
1QWKGS4's Avatar
1QWKGS4
thanks in advance.
I had a hard time too when I was trying replace my Rod Millen bumper with an alternate bumper -- I know we've all heard of horror stories about Fiberglass bumpers and some of those stories are true but thru much research - there are two types of fiberglass bumpers.
1. Regular Fiberglass
2. (FRP) Fiberglass Reinforced Plastic
Most of the newer kits are made using the FRP material which is pretty durable. Don't let the word "Fiberglass" scare you. I'm pretty picky what goes on my car and I won't put nothing but the best parts on my baby.
Originally i had a mis-match kit; I had a RM Front Bumper (urethane) and Veilside skirts (FRP) and Veilside Rear bumper (FRP). At that time, I didn't know anything about FRP, i just thought, "its Fiberglass and i need to be extreme careful with it" Having the kit setup from 2001-2007 - I've had more issues with the Urethane front bumper than the rest of my kit. I've had the front bumper painted like 2-3 times due to paint-flex issues (the bumper is a bit soft and does flex) which cause some issues and the fitment wasn't that great. I even had to replace the front bumper for hitting some debris on the hwy (it cracked) and puzzling how I haven't any issues with the FRP skirts or rear bumper. Moving forward to when i decided to replace the RM Bumper due to clearance issues, I decide to go with Tom's because of their reputation and products are Top notch and that the Tom's kit continue the Veilside look without having to re-do the whole car.
I had an experienced shop who only work on hot rods, classic & muscle cars painted my kit, and from what they said, "The fitment and quality of the Tom's FRP Bumper was the best they've ever seen" and they been in business over 30 years.
A testament that FRP is just as good, On my move from ATL to TX, I had my front end taped up for the 800 mile drive and in Beaumont, TX i hit a large plank of wood that came off a truck and hit my bumper and scar my headlights and scuff my Passenger Front Wheel. Arriving, I pulled off the tape knowing i would see damage underneath.. to my surprise, no cracks, no spider-webbing, not even a blemish - NO DAMAGE at all.. The FRP is strong or atleast the Tom's FRP is that strong. Now having experience what I have experienced going with a Reputable company known for their history even though they might be more expensive (Cost is not the issue) getting a great product is most important.
So, though if i could have found a Urethane bumper to match my Veilside look, i would have gone with it but consider the FRP stuff because they are not as fragile as the old fiberglass stuff we've all heard of..
It was tough going from Urethane to FRP, but I am very happy with the Tom's but not saying the Rod Millen isn't good. But For Fiberglass (FRP) I haven't had any issues with my new bumper.. My 1st Rod Millen bumper was a bit soft and flexes which caused some issues hopefully the replacement i had which i sold to you was made 5 years later, hopefully you won't have any of those flex issues.. From what i can tell - Your bumper seemed more sturdy than my 1st bumper.
You know alot, Sir!
Old May 13, 2011 | 04:25 PM
4eign's Avatar
4eign
i think i may have found a kit (used) for cheap and seems to be FRP material. Question thos...is it a mix of fiber glass and poly?
Thank u everyone for your input and info, truley y i love this site. u guys rock!!!
2jzSwizzy
Nov 16, 2017 12:13 PM
DBO617
Aug 19, 2010 06:57 AM
buNNyIS
IS - 1st Gen (2001-2005)
Dec 13, 2004 11:53 AM
XpLiCiTe IS
Feb 17, 2004 01:03 PM
Xpicy
Oct 4, 2003 10:12 PM
