Need help on alternator pigtail......
Does anyone have any info on the plug that goes into the alternator on a 02 gs300. the wires pulled out of the plug now in not sure which order they go back in...... to get this part at the dealer they want me to buy the entire engine harness for the car.
please explain a little more. wires with terminals dont just come out of the plug unless they were tugged on with force or got caught in a moving belt or someone forgot it was still plugged in when removing the alternator.
so my question. is the plug damaged? are the wire terminals damaged? if not, you can push them back in.
and....YES you can get the Alternator plug seperately
Look at another 01+ GS300 or maybe someone will post a pic of their car Alt plug so you can see the color sequence. Below are teh part numbers to replace the plug and wires. You will need to cut yours and re-solder. Based on your post, I suggest having someone who knows what they are doing, do this.
Alternator Plug Part # 90980-11349
Wire Terminal Part # 82998-12440 (x3)
yes the plug is damaged, i accidentally pulled the wires out while trying to take it off the alternator. i.e... the terminal was still in the alternator and the wires were in my hand.
The 3 wires that go into the alternator plug are red/pink/white each one with a blue stripe. Can someone here with an 01+ gs300 maybe take a pic or look and tell me me which position each wire goes.
