ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   GS - 2nd Gen (1998-2005) (https://www.clublexus.com/forums/gs-2nd-gen-1998-2005-184/)
-   -   Here's my stupid mistake... (https://www.clublexus.com/forums/gs-2nd-gen-1998-2005/538290-heres-my-stupid-mistake.html)
poohunny Nov 24, 2010 01:08 PM
I went to replace my air filter and clean my MAF today. When I went to unplug the battery (and yes I know better but wasn't thinking when I did it...:egads:) I unplugged the positive side only. I put a cloth over the terminal like I always do, and got to work. Hooked everything back up, no problem. However, my memory seats now do not work. I went to set the buttons again and did not hear any beeps....Everything else works like it always had...except this. Could I have screwed it up the memory seat module really bad? Or is just coincidence?
ThomasGS4 Nov 24, 2010 01:28 PM
Try unplugging the negative terminal this time to reset everything and see if it'll work.
GSteg Nov 24, 2010 01:37 PM
Checking the fuses should be your first step.
Next time you pull out the negative terminal, not positive.
poohunny Nov 25, 2010 05:45 PM
fuses were good, but right on 1UZ-GS, unplugging the neg for 30 seconds did the trick! muchas gracias!!
ThomasGS4 Nov 25, 2010 05:48 PM
Glad to help. :thumbup:
sakataj Nov 28, 2010 06:44 PM
wonder if this would work on the stupid mistake i did this weekend.... :rolleyes: doubtful but always worth a try especially since i checked all my fuses,wiring,connections,etc....
SIGH
