Wheel width/offset/size and tire fitment Q&A thread
Old 07-08-19, 06:57 PM
  #1006
Riksgs808
Riksgs808's Avatar
Originally Posted by MrPogi86
19x11 + 7 / 225/40
19x11.5 0 / 245/35
On air and adjustable arms
i know it’s aggressive just wondering if it’s remotely possible with a pull. Trying to get a flush fitment.
Are you trying to get flush while at ride height or airdout? That fitment will never be flush when airdout. You can get it flush with a hard pull but you won’t be able to air out all the way. The rear quarter would have to be trimmed higher to get that flush properly.
Old 01-02-20, 10:47 PM
  #1007
BraceGS
BraceGS's Avatar
Default Wheel Fitment Question 19x10.5
Hello. I may have access to getting a set of 19x10.5 +18 (all around) wheels locally. Looking to see if this setup will work on my GS? I currently have stock wheels and suspension. The wheels in question are on another 2nd Gen currently, however, it is on coil overs and aftermarket rear control and toe arms. Unfortunately, I do not know tire specs, but I do know there is mild stretch. I am sure the rear will work fine, but I am not seeing much in way of 10.5's up front in my searches. Take care.
Old 01-03-20, 12:11 PM
  #1008
firelizard
firelizard's Avatar
No........
Old 01-04-20, 05:32 PM
  #1009
jefthim
jefthim's Avatar
All - I'm on my 3rd - 2nd Gen GS and I'm debating a new wheel and tire combo to me. I like the idea of the staggered fit to place the HP at the rear wheels to the ground, and in the past I have run 235/35/19 +35 fronts and 275/30/19 +35/40 rears. Keeping with the original factory spec for the spedo. After bending so many wheels I'm on the verge of pulling the trigger on a 235/40 front with a +35 offset and a rear 265/35 +40 offset setup. Has anyone else ran this package and if so were they happy with the extra meat?
I understand this combo will change the way the odometer tracks my mileage, but lets face it...the car is almost 20 years old and has 146k with the original factory bent up wheels. Just looking for some feedback...BTW I'm on TEIN Street Basis with adjust-ability for height.
Thank you all!
Old 01-23-20, 09:14 AM
  #1010
ShadowSC
ShadowSC's Avatar
I'm trying to see if the wheels listed below will work with my setup? What tires, will fit with brakes? Offsets might be too high I'm thinking.
Any help would be appreciated?
Car:
2003 Lexus GS300
Coilovers
Fenders NOT rolled (no plans to)
Brakes:
Front LS460 4pot w/ 14" rotor
Rear LS430 2pot brakes w/Supra TT rear rotors
Potential Wheels:
SSR Professor SP1
19 x 8.5 +37 w/HP disk
19 x 9.5 +43 w/SL disk
Old 01-23-20, 05:39 PM
  #1011
firelizard
firelizard's Avatar
Can't speak on the brake clearance, but this CL user has almost the same wheel specs.
https://www.rimtuck.com/setup/view/1881
This person has 10.5 +38 in the rear which has less inside clearance than 9.5 +43, therefore your wheels should fit.
https://www.rimtuck.com/setup/view/1250
Old 03-02-20, 09:06 PM
  #1012
Arussto
Arussto's Avatar
Default Rays progressive MEs
So what you guys think of 19 x 9.5 at 20lbs?
just rear for now . Had to save for fronts. In mail.
and yes! Black cars DO look better in the shade
Old 03-07-20, 05:39 PM
  #1013
whylie421
whylie421's Avatar
GS300 on 22"s
Old 03-07-20, 08:28 PM
  #1014
8M6
8M6's Avatar
Old 03-22-20, 06:58 PM
  #1015
Bongizzle
Bongizzle's Avatar
Default SVE wheel fitment questions.
Good evening everyone, I have serveral questions for the guys who know a thing or two about fitment and tire sizes. I've searched around basically everywhere for someone who has SVE series 3 wheels on their GS and it almost seems like nobody runs them. I plan on being one of the few to do it so I just wanted to find out what tire size would I be able to get away with running on my GS in the rear and front. My wheel specs are 18x9 fronts 18x10 rear. Would 285/45 rub in the rear? I do also plan on running some spacers so I can get that agressive stance in the rear.
Old 03-23-20, 03:22 AM
  #1016
Tuanville
Tuanville's Avatar
You might get some rub. What are the offset? I had 18x10 +15 running 245/45/18 and I still had to roll my fenders.
Old 03-23-20, 03:36 AM
  #1017
Bongizzle
Bongizzle's Avatar
18x9 +24 in the front and 18x10 +20 on the rear.
Old 03-24-20, 10:27 PM
  #1018
BayAreaLex
BayAreaLex's Avatar
18x9 24mm 245/40/18 will be fine on the front with a lip roll.
18x10 20mm will poke. With shaved fender lips a stretched 255/40 should clear... any wider and my bet is you’ll rub.
I don’t care for those particular wheels but always wondered how Bullitts would look on a GS.
Bongizzle (03-25-20)
Old 03-25-20, 12:44 AM
  #1019
silverbul
silverbul's Avatar
I ran that 245/40 in the front & 265/35 in the rear for yrs with no problem. I tried running a 40 series tire in the rear & every couple of months I was replacing them. Sidewall bubbles & steel belt breaks. That's when I learned about vehicle load capacity. I'm running 19's now.
Old 03-25-20, 06:50 PM
  #1020
BayAreaLex
BayAreaLex's Avatar
265/35 what what diameter, width, and offset?
And I’m not following your comment about 40 series tires and load capacity. There should be no issue running 40 series tires unless your tire was kissing your fender.
Quick Reply: Wheel width/offset/size and tire fitment Q&A thread
