Will it fit?
Quick question. Will a set of 18x9.5's with a +35 offset, with 245/45/18 tires clear stock struts loaded with Tein S-Tech springs? NOt sure on the amount of available room between tire and spring perch on stock suspension.
you should be using a 245/40R18. the tire size you mentioned is oversized by quite a bit and may rub if you are lowered. but they wheel should fit fine
^^^^^thanks for the reply. Long story short....it's only temporary. Thanks again for the input
