Lsd Install
The pic of the whole pumkin (RMM,Supra TT) has 3.76 gears and you can just swap the units out...
The LSD that you bought is just the LSD, you have to install it yourself. The TRD LSD (clutch type) are supposed to be stronger than the RMM,Supra TT (Torsen type) atleast that's what Steve Ganz told me...
The TRD LSD has to be installed by a person who knows what they're doing. Shimming it wrong can put pressure on the bearing and cause wearing and damage to the ring and pinion. I would recomend going to a well known 4 wheel drive shop and having them do the job because they always change and install LSD, Lockers, and ring and pinions.
Either way you made a good decision on getting the LSD...
Aloha
Aloha
Guest
Posts: n/a
Most of my friends favor in Torsen but since TRD chose the clutch type, it must have its reasons. And you can trust products from TRD. The gear ratio is different therefore you will reach red line faster with Torsen and higher rpm at freeway.
Also Torsen type is easier to install since it's bolt on and clutch type you have to do a lot more work.
Both types of LSD attract two different groups of people.
Is this the correct picture for the TRD LSD?
I am going to show to my Dealer.. see if they want to deal with it. If not, I'm certainly not going to buy this.. so some shop can fool arround with my car..
If anybody remembers the crazy blowout deal Steve had many moths back for LSD at less than $500. Were they the TRD clutch type?
And the new group buy on LSD, were they the Supra torsen type?
I guess my question is, which is cheaper? If I do this I want easy install. Not may shops around my town that I would trust with this.
Overclocker
Overclocker
Guest
Posts: n/a
Shin,
YES. This is the TRD LSD.
The different between Torsen and clutch type is, Torsen type is torque bias, so it's partially locked depends on the wheel spin. The clutch type is either fully locked or fully un-locked. If you have higher HP, you definitely need TRD unit. My friend's 700 hp SupraTT can spin the tires even at 3rd gear with Torsen style LSD:eek:
My .02 on this Torsen vs Clutch Type LSDs:
Unless you are building a drag monster with upwards of 5,6,7,800 HP, I don't think you really need to worry about blowing up your LSD.
But similar to whatRA said, to each his own.
Originally posted by DrRick
i think that there is some misinformation going around about the LSDs. i think that what we need is the total bell housing that has everything already assembled. i spoke with a toyota rep yesterday and he was telling me that i need all kinds of bearings and all. from looking at the pic, it looks like a self contained unit and direct install. also i want to know if the rear drive ratio is the same for the TT automatic and 6 speed.
I believe....
The TRD is an easy install also, Ive seen it done...
ok i am going to ask this one more time:
WHICH LSD COMES AS A COMPLETE PACKAGE (PUMPKIN) AND WHICH ONE COMES AS JUST THE CLUTCHES AND INNARDS!!!! please help!!!!!
Doc
Doc
TRD LSD is the innards (spider and clutch assembly). You reuse the ring gear and pinion gear. It is a 2-way clutch type with stock 3.26 ratio. Installation estimate is about 6 hours.
You can't go wrong with either LSD. Either will greatly reduce wheel spin.
The Supra is more expensive to purchase but cheaper to install and will give you a little more torque/acceleration. Your RPM's will be higher at a given speed which could be a neg. if you do alot of highway driving.
The TRD is cheaper to purchase, but more expensive to install. It can handle more power and will provide torque in extremely low traction situation, i.e. snow/ice.
I chose the TRD. It was the low cost option for me since I did the install myself. It will minimize wheel spin and better snow/ice traction was a benefit for my location.
Originally posted by RacingAristo
What? This is ridiculus. Dealer couldn't install the LSD? That shows how much Lexus mechanics know.
Originally posted by BadBtsz4u
Wait, I thought the RMM lsd provided more accelaration off the line making it better than the trd lsd no?Or am I misundestanding the use of lsd
The Supra TT/RMM LSD also has a gear ratio of 3.76 that will slightly increase the torque to the rear wheels over the stock 3.26 ratio.
LSD appears to be the hardest decision I'd need to make.
