Help GS300 engine with PIC's
Hello CL members i have noticed that oil sprays upwards from the timing belt housing and also i have noticed a leak under the car see pics and if anybody knows how i can fix these problems pleas let me know and what to buy because i want to do this ASAP thanks i appreciate it once again
http://i174.photobucket.com/albums/w...s/DSCF3388.jpg |
either valve cover gasket or front main seal. Either way, not super cheap.
what about the leak on the differential
Originally Posted by GSRSRT
(Post 5141075)
It could come from alot of places.. Did u clean the timing belt or is it new? That's kind of hard without being there in person. Maybe, u should take pics from about 2-ft. instead of 5-in. away. Just keep in mind that when your driving the oil is going too run(fly) everywhere. Maybe u should clean(wash) all the oil up. Then u might be able to narrow it down. Hope that help! GL
i already did that and had my timing belt change recently and i cleaned everything now its wet again so i hope someone in here can narrow it down for me thanks
(Post 5141106)
engine bay: -front main seal (should have done at same time as timing belt) -Valve Cover Seal Diff: -diff cover, and input shaft seal. |
Originally Posted by jcat_GS3
(Post 5141154)
my responses are the most likely culprits.
(Post 5141106)
Radiator out covers off remove cambelt replace crank seal and cam seals should have been done same time as water pump and cambelt replacment Info to change cambelt and crank seal can be found here http://www.turbosupras.com/pdfs/JZA8...20(2JZ-GE).pdf |
Agreed.. I had this same issue when I changed the crank pulley and did not have a good seal. Thought it was something else like a cam seal but it was not...get a new timing belt too...
Originally Posted by Jason T
(Post 5141449)
Crank seal is leaking best to replace cam seals at same time replacment should be a 4 to 6 hour work shop job
I have a 01' GS430 and has a semi-common rear differential front pinion seal leak. I had one on my 00' 400, and and so did my friends, however he now has a 430, which doesn't. I used to work at Toy/Lex, it's more common than people thing. As far as the engine leak, I would Guess it's a Cam/Crank seal, but I don't have a 2J, so I'm no expert there.
Originally Posted by 3UZFTE
(Post 5141590)
thanks guys soo much but to answer some of your questions i have a new timing belt and a new water pump i told the mechanic to change the seals but i guess he didn't do it so yea now i have to do it my self or find someone that can do it for me at a reasonable price. by the way I'm 23 years old and i got this lex last year in January from an old man and i don't really know people who can work on Lexus cars or help me out am by my self on this so all your opinions will really help me out a lot
(Post 5141449)
(Post 5141154)
| All times are GMT -7. The time now is 08:23 AM. |
