Pinging on GS4
Old Nov 6, 2009 | 11:02 AM
GSquicksilver's Avatar
GSquicksilver
Default Pinging on GS4
do any of you guys get pinging on your GS4? it usually happens to me when i accelerate after coasting, not from a dead start.
Old Nov 6, 2009 | 11:47 AM
Infamous 1's Avatar
Infamous 1
where is the pinging coming from? do you hear it when you are standing outside? cheap gas over the years will cause a pinging.
Old Nov 6, 2009 | 12:24 PM
3UZFTE's Avatar
3UZFTE
Maybe it's not premium, I haven't really experienced it, but I have read that lower octane can cause some pinging.
Old Nov 7, 2009 | 11:59 AM
GSquicksilver
I use premium 91 and hear it sometimes while driving. I think it happens more when the car has been running for extended times.
Old Nov 7, 2009 | 03:40 PM
edro925's Avatar
edro925
Sounds like bad gas. Try some octane booster.
Old Nov 7, 2009 | 05:06 PM
GS300ToM's Avatar
GS300ToM
got enuff coolant or oil... check that first
Old Nov 7, 2009 | 06:11 PM
lextechGS's Avatar
lextechGS
Usually cheap gas is the culprit. I recommend using only premium fuel. Also, get a BG induction flush...that should clear out a lot of the carbon build up in your intake system.
Old Nov 7, 2009 | 10:49 PM
silverdust's Avatar
silverdust
i use premium for ten years no pinging yet also check oil weight
Old Nov 7, 2009 | 11:35 PM
Och's Avatar
Och
Its your K&N filter. Get rid of that garbage, get a stock air filter and clean your MAF sensor with CRC MAF cleaner.
Old Nov 8, 2009 | 02:52 AM
LT4mula's Avatar
LT4mula
same issue on my 430... I want to pull a plug to see if it really is ping... I only run 91.
Old Nov 8, 2009 | 09:48 AM
Och's Avatar
Och
https://www.clublexus.com/forums/gs-...hlight=pinging
Old Nov 9, 2009 | 11:22 AM
sakataj's Avatar
sakataj
IF, its the filter its CAUSE THEY over-oiled it not cause of the filter. cant help that you, (OCH) cant read and follow directions on how oil a airfilter. i have run my k&n on my gs430 for over 2 years NO PROBLEMS, NO ISSUES, NO CELS, NOTHING.
OP its probably gas....cheap gas. did u recently add some 85? or 87? whaetevr you'll have there? we lucky enough to have 93 here lol
Old Nov 9, 2009 | 05:49 PM
Och's Avatar
Och
I only had my K&N filter for a year, I never oiled it. Just because you don't have issues doesn't mean it can't cause issues. I suggest you inspect your MAF, you will see buildup on it.
Old Nov 11, 2009 | 12:57 PM
sakataj's Avatar
sakataj
well, directions state u should oil it so maybe you shoulda. i have checked and rechecked my MAF no oil residue.
Old Nov 11, 2009 | 03:31 PM
GSquicksilver
i've always used 91 gas. regardless if i use shell, 76, or chevron, i still get the occasional pinging. i clean my maf out twice a year, and make sure the k&n is not over oiled too. maybe i will try an oem filter and see what happens.
iowaman
12
May 25, 2017 04:01 AM
SgtIk3
IS - 1st Gen (2001-2005)
Aug 15, 2016 10:32 AM
SebaPR
Sep 28, 2015 04:13 PM
OCLEX03
Oct 15, 2010 11:44 PM
disc400
Jun 15, 2009 05:26 PM
