P0161 code on GS430
Old Jul 27, 2009 | 08:42 PM
Kytann's Avatar
Kytann
Default P0161 code on GS430
Hello. I've done a search on the P0161 code, but the majority of the information seems to me for the inline six GS300's
P0161 is O2 sensor heater malfunction, bank 2 sensor 2
Now my question is where is this in real life?
I'm guessing passenger side after the cat.
Is this correct?
Now I've had a heater fail on me before on an o2 sensor that was after the cat. The only real purpose of an after cat o2 sensor is to make sure your catalytic converter is not worn out. The o2 sensor before the cat is the one used to make adjustments to the fuel trim.
Knowing that I see no real benefit to the operation of the car to heat up the sensor.
When this happened before I located the wiring for the sensor heater, and spliced in a resistor I bought at radio shack. This cost $5 and worked great for the rest of the time I had the car.
Only trick was that resistor got really hot, so I used a metal hose clamp to attach it to a metal bar to act as a big heat sink.
contemplating this approach.
Question becomes then, where is the wiring for the B2S2 o2 sensor?
And of course, where is the actual sensor?
Old Jul 27, 2009 | 10:30 PM
GS300ToM's Avatar
GS300ToM
theres plenty of threads about this... just hit the search button for oxygen sensor
Old Jul 27, 2009 | 11:32 PM
Debonair's Avatar
Debonair
Searching will help you find "Pics Of Location Of Oxygen Sensors"
Old Jul 28, 2009 | 12:17 AM
GS4_Fiend's Avatar
GS4_Fiend
Is this correct?
Just change it don't play games. Yes, it's on the passenger side. The connector is on the passenger side where you would have to lift the carpet out to replace it.
Old Aug 5, 2009 | 08:35 PM
Kytann's Avatar
Kytann
It can be accessed from in the cab of the car? Wierd.
I'll look for it this weekend.
As far as searching, as I stated above, I did search. Didn't find hardly any information specific to the V8's. Everything that I found seemed to be L6 specific after reading EVERY post that came up from a P0161 search.
Is there some other way of searching that I'm not familiar with?
Anyway, there was some descriptions for the L6 guys, but it wouldn't make sense for the two engine types to have the same exhaust layout. THerefore location information for an L6 has no bearing on a V8. After all an L6 doesn't have two banks of cylinders.
Old Aug 5, 2009 | 09:53 PM
Debonair's Avatar
Debonair
I handed that one to you.
And the I6 does have two banks.
Old Aug 10, 2009 | 02:38 PM
Kytann's Avatar
Kytann
Thanks alot, those pics really help!!! Exactly what I was looking for.
In hindsight, yes you did hand that one too me. Should been more observant and noticed the quotes.
Also, I stand corrected on the I6, it does have two exhaust banks. Must have to do with exhaust scavenging, like how on a 4-cylinder sport bike it makes sense to have the collector as a 4 into 2 into 1, rather than a 4 into 1.
Upon examination of the part, it's been mashed up at an angle and no longer comes straight outta the exhaust pipe.
I think what happened is when I had the car jacked up I had a 2x4 chunk in between the jack and the frame rail, and when I let it down off the jack that board got all ****-eyed and musta bent it. Seems like it happened just before the light came on.
Therefore I've got a replacement sensor on order from Rockauto for less than half what the dealership charges.
Thanks guys
coug66
Sep 23, 2019 09:33 PM
coug66
Jun 7, 2019 05:02 PM
lpscooby13
GX - 1st Gen (2003-2009)
Jun 28, 2014 01:55 PM
nicos1
Nov 5, 2007 05:47 PM
BklynJay
Performance
Nov 19, 2006 10:39 AM
