how do i replace a fuse
Old Jun 18, 2009 | 07:56 PM
vip..me's Avatar
vip..me
Default how do i replace a fuse
so i just got a viper alarm installed and the abs lights and vsc lights came on. after some trouble shooting we found out that it was a blown fuse . so the question is how do i replace a fuse . its the 60 watt fuse thats blown . thanks
Old Jun 18, 2009 | 08:58 PM
Infamous 1's Avatar
Infamous 1
Buy a new fuse, check either by the kick panel or under the hood for the blown fuse, pull out the old one, and pop in the new one.
Old Jun 18, 2009 | 09:31 PM
Jason T's Avatar
Jason T
60amp is a major system fuse to blow you need to find why it blew
Remove the plastic clear cover and you can bridge the terminals if it melts straight away you need to get your car to who installed the alarm and fix it
To replace with new fuse you need to unclip 120amp & 60amp from main fuse box to unbolt for under side easy way is Unbolt complete fuse box remove under side cover to access
I would recommend bridging first to find and fix fault before you bolt in a new one
Old Jun 18, 2009 | 10:04 PM
vip..me's Avatar
vip..me
thanks will try tomorrow , but i have no idea why the fuse was blown, a friend said the same thing blowing a 60 watt fuse is no bueno.. the car is a 05 gs that i got 3 weeks ago should i be worried
Old Jun 18, 2009 | 11:18 PM
GCOP's Avatar
GCOP
CL Folding 100,000
Solid advise. 60AMP is big time. It could be just a fluke..BUT if you replace it, and blows quickly, there is no doubt a bigger issue. Let us know how it pans out.
thelawnet
Maintenance
Nov 7, 2024 04:45 PM
ALLWiTE2JZ
Oct 23, 2011 03:09 PM
mcnelson
Aug 5, 2002 05:13 AM
ivc
Aug 2, 2001 10:21 AM
