Hey Debonair. You sound knowledgeable on this. My factory spoiler is getting loose. How do I fix it? When I open the trunk I look underneath, I don't see and mounting bolt. I think it's taped? Anyhow, how do I fix the wiggle? Thanks.
mine's loose also, but it's not the wing to bracket being loose, I took the wing off, and wriggled the bracket, it's the bracket being loose... I think it's the rivets and I was planning to re-rivet them, but I don't know what type and if it'll hold....
You take the trim pieces off that coversthe bolts mounting the spoiler to the bracket and just tighten it up.
I think they may use an adhesive in addition to the bolts and brackets.
Any one know how to stop the free play on the spoiler?
Open your trunk and look at the underside of the spoiler where it hangs over the sides of the trunk lid. Remove the "Rear Spoiler Covers." I believe they just pop off with a screw driver. You can then check and see if the spoiler bolts are loose. If they are you can tighten them and put the covers back on.
If this is not the issue the rivets that hold the "Rear Spoiler Side Retainer" (bracket) to the trunk lid may be loose. You can remove the spoiler and check them. The rivets would have to be drilled out and replaced if they have become loose.
