avic install ?
Old Mar 5, 2009 | 10:30 AM
bigjez's Avatar
bigjez
Default avic install ?
I have looked and cant find anything on this i need to find the reverse gear signal so that i can finsh my avic f700 install
Old Mar 5, 2009 | 10:34 AM
bigjez's Avatar
bigjez
also what wire on the lil conector(behind the radio) is for the power ant.
Old Mar 5, 2009 | 10:38 AM
LeXaNoMicS's Avatar
LeXaNoMicS
Have you tried the AVIC install DIY in the DIY sticky page ?
Old Mar 5, 2009 | 10:39 AM
bigjez's Avatar
bigjez
yep and it does not say i look at all diy radio installs and nothing
Old Mar 5, 2009 | 10:46 AM
sam430's Avatar
sam430
Same here... I haven't completed my DNX install yet because I can't find the reverse signal... Well, I found something last night. There is, finally, a link to the repair manual that works.
I want to also tap the Illumination wires at that level too instead of going up to the clock area (which is the middle wire ..based on the repair manual.. I prefer the radio area, but I will have to look for that).
Old Mar 5, 2009 | 10:47 AM
Stage3's Avatar
Stage3
Here you go...
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Brown
Radio Ground Wire: Gray
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Power Antenna Trigger Wire: Black/Red
Radio Amplifier Turn On Trigger Wire: White/Blue
Front Speakers Size: 5 1/4″
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 5 1/4″
Rear Speakers Location: Rear Door
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Old Mar 5, 2009 | 10:50 AM
bigjez's Avatar
bigjez
I use the light green wire right off the radio th smaller connectotfor illum man i have been looking and still nothing on the reverse signal.
Old Mar 5, 2009 | 10:52 AM
bigjez's Avatar
bigjez
the gray is 12v switch power not the brown
Old Mar 5, 2009 | 10:53 AM
bigjez's Avatar
bigjez
and for give me if iam slow but Radio Power Antenna Trigger Wire: Black/Red were is on the big connec or the small on the radio connectors and Stage3 thank for the help just still lost right now.
Old Mar 5, 2009 | 10:55 AM
sam430's Avatar
sam430
Originally Posted by Stage3
Here you go...
Is this for the gs?
What is that used for? I'm confused, is that suppose to be the mini-round-atenna ?
There is two plugs that plugs into the back of the pioneer radio. One plug has two wires and the other plug has a whole bunch of wires (which I have adapter for it).
There are two antenna. One mini and one large (not sure if both can be used but there is an adapter for the mini at a local pepboys).
Old Mar 5, 2009 | 10:58 AM
sam430's Avatar
sam430
One down. Thanks!
Old Mar 5, 2009 | 11:00 AM
sam430's Avatar
sam430
http://bahamutcars.free.fr/workshop/...nts/index.html
This link works.
Old Mar 5, 2009 | 11:11 AM
Stage3's Avatar
Stage3
Originally Posted by sam430
Is this for the gs?
Yes... That's for the 99- GS... I used that same schematic for my Eclipse install and it was as smooth as butter...
Old Mar 5, 2009 | 11:14 AM
bigjez's Avatar
bigjez
Thanks
nice
Old Mar 5, 2009 | 11:25 AM
sam430's Avatar
sam430
Did you use the mini-antenna at all? My receptions aren't great even for local stations. (I'm going to pepboys to see if attaching the mini-power-antenna would improve reception).
This is my first time installing a radio...so my questions may be obvious. I'm still looking for the reverse signal.
Laza1
Jul 20, 2024 01:43 AM
Sjfarney
GX - 1st Gen (2003-2009)
Sep 29, 2018 02:53 PM
EVC1959
Nov 14, 2007 07:59 AM
BKzSC400
GS - 1st Gen (1993-1997)
Dec 27, 2006 02:29 AM
Dx3
May 3, 2004 10:52 AM
