Heres an idea
Old Feb 16, 2009 | 06:17 PM
mtparker18's Avatar
mtparker18
Default Heres an idea
Someone should mod thier ignition and key to be like the 3rd/2nd gen is/gs. The wireless key and the push button where the key should go...anyone think it could work?
Old Feb 16, 2009 | 07:05 PM
Big Mack's Avatar
Big Mack
Unhappy
Well, given that you'd have to modify the transponder in the key to be a transmitter instead of a chip and the verification in the car to be a receiver, it's not going to be an easy option. Of course, if you've already installed a remote start like some of us, you could quite easily use the switch to lock in the "on" position once the car has started. Still going to require some serious modification, though, because you need to ensure it can be safely shut off and not accidentally left in the "on" position to kill the battery.
Big Mack
Old Feb 16, 2009 | 07:11 PM
mtparker18's Avatar
mtparker18
Big Mack
Ah, I knew it was going to be tough
Old Feb 16, 2009 | 07:13 PM
Downfall75's Avatar
Downfall75
I've seen this done on a Supra. I just don't remember where.
Old Feb 16, 2009 | 07:14 PM
UncleRay's Avatar
UncleRay
You could probably hack a servo into the ignition to start the car by it self via remote lol
Old Feb 16, 2009 | 07:18 PM
DarKnight's Avatar
DarKnight
Just get a remote starter and call it a day.
Old Feb 16, 2009 | 09:02 PM
mtparker18's Avatar
mtparker18
haha, I just thought it'd be cool to do a DIY on it. but you'd have to replace a bunch of shizz.
Old Feb 16, 2009 | 09:06 PM
JoelGs's Avatar
JoelGs
I have thought of this a while back and found out that it is a heck lots of trouble to go thru to get it done..just save some money toward something else...
Old Feb 16, 2009 | 11:06 PM
jcat_350's Avatar
jcat_350
someone did do it to a supra using the module from the infiniti's. You can buy the kit for about 500 bucks, i think i remember it taking a couple other small mods for a lex though. Just search youtube for supra push button start or something and youll find it.
Old Feb 16, 2009 | 11:29 PM
LeXaNoMicS's Avatar
LeXaNoMicS
Take a look if it can be done in SC/IS why not GS
http://drespecengineering.com/
Old Feb 17, 2009 | 04:39 AM
DarKnight's Avatar
DarKnight
Hey that's not a bad price if it'll be the same for our cars. It's about the same price as Viper 791xv but you don't get remote start or the two-way pager.
Old Feb 17, 2009 | 07:37 AM
LeXaNoMicS's Avatar
LeXaNoMicS
you should get it and let us know how it works
Old Feb 17, 2009 | 08:41 AM
DarKnight's Avatar
DarKnight
Sure I'll take donations & contributions lol.
Old Feb 17, 2009 | 09:16 AM
LeXaNoMicS's Avatar
LeXaNoMicS
i emailed the company today requesting more info for us , ill update ya sooon...
He got back to me really fast .....Here is what he said ....
Thanks for the email. I've been flooded with requests to adapt this to many other vehicles, but it currently takes me 2-3 weeks to build each one just for the Supra. I am looking at a way to mass produce these so I can spend time on adapting them to other makes. This unit could definately be adapted to a GS but I would need to see some basic information (ignition wiring diagrams, button placement, if the GS can be driven without the key cylinder in place, if there are special alarm/fobs that I need to disable, etc).
I had considered offering a cheaper barebones kit where the user would have to figure out the wiring. The kits are going for $549 for Supra members, complete units, pretty much plug and play. The barebones kit wouldn't contain the infiniti key-in-fob nor a custom fit button nor a plug-n-play ignition harness. You would have to provide your own button and use small fobs that I provide. You would have to wire up your relays and source a turbo-timer harness or splice your own ignition harness. Also, you would have to figure out the ignition wiring coupling all your own (which you can do with an ohm-meter and moving the key to all positions). I would provide documents showing how the Supra is wired for reference and provide installation support. This is the only way currently that I could get these out quicker.
Pass the message along, see if there is interest. I could probably get the barebones kit down to $295-$390, but it would provide all the functionality. This would be the cheapest fully supported kit out there espcially coming from a DIY'er like myself. Most kits don't incorporate special features, I can add them depending on complexity.
- Andre
Enz
RX - 1st Gen (1999-2003)
24
Aug 2, 2014 12:08 PM
hoonunya
May 23, 2012 05:41 PM
cubabarber
May 18, 2012 10:22 AM
melski415
Jan 16, 2009 01:20 AM
VQT
Aug 4, 2007 03:39 PM
