Loud Clunking/Creak Noise
it happens when i turn , specially on left turns so im guessing its my left ball joints right?
any idea how much a shop will charge? |
Originally Posted by LiLS
(Post 3991877)
any idea how much a shop will charge? my mechanic said my balljoints are fine. |
(Post 3991877)
any idea how much a shop will charge? $130 for a set of front balljoints. Labor should be an hour only. |
I had a similar sound during low speed turning. With the observations you've described, it could be related to the sway bar.
im pretty sure its my balljoints, well hopefully it is cuase i just ordered some and a pittman arm puller...
anyone know of a good DIY guide? |
(Post 3995611)
(Post 3995611)
Originally Posted by jcat_GS3
(Post 3995688)
check the sticky at the top of the forum, it's been done a hundred times and shouldn't be too tough. good luck :thumbup: probably the best piece of preventative maintenance you can do on the car.
Originally Posted by Coco-bun
(Post 3995699)
there's a DIY somewhere. And you should have just rented the puller from Autozone ;)
