Starting Issues
Old Sep 14, 2008 | 12:27 PM
truenoboy's Avatar
truenoboy
Default Starting Issues
I've been haivng sometimeish starting issues for the last few days now. Sometimes when I turn the key, I can hear a click, but nothing happens. Other times, the car just fires right up with no delay or strugle. All electronics work, but the car wont crank. The battery is farely new as I bought it in Jan. I checked anyway with my DMM and got a reading of 12v with key off, and 11.4 when trying to start the car. This morning I even had somebody crank the key while I hammered the started just incase it was a starter issue, and nothing. I disconnected the battery for a little, connected it back, and the car started right up. I can not figure out what on earth the issue is, but there's no consistancy. Hot or cold doesn't matter as the issue happened once mid day yesterday (90+ degrees) and late last night (70/80 degrees).
Any suggestions? I'm wondering if it is the computer, but I have no way to check to know if it is.
Old Sep 14, 2008 | 01:05 PM
chrispy's Avatar
chrispy
If it's a single click, it's probably the starter. It might be on it's way out.
Old Sep 14, 2008 | 01:33 PM
truenoboy's Avatar
truenoboy
Hmm....tell me somehting. How and why would a car make multiple clicks? And also, if it's the started, wouldn't it respond when I hammered and cranked the car at the same time?
Old Sep 14, 2008 | 01:44 PM
chrispy's Avatar
chrispy
If it makes multiple clicks, the starter works and it's probably the battery not having enough power to start the car. I had my starter replaced on my GS400 before and those were the same symptoms I had before.
Old Sep 14, 2008 | 02:05 PM
truenoboy's Avatar
truenoboy
It can't be the battery. If it was, the car wouldn't start sometimes. It should never start. Did you ever try the knocking the starter technique when you had your issues. To my knowledge, that's a good way to test for starter issues.
Old Sep 14, 2008 | 04:18 PM
JeffTsai's Avatar
JeffTsai
It's a very common issue for Toyota V8 starters. It seems to affect the GS more than the other Lexus. If its a single click, and then silence then it's the starter. If it's clicking rapidly then the battery is low. The one click of death syndrome is something that you will for a little while and shortly after that the starter completely refuses to work at all. It seems you're somewhat mechanically inclined. Changing out the starter on the V8 is not rocket science, it just takes a while to do since you have to pull off the whole intake manifold. You can pick up a remanufactured starter with lifetime warranty from Autozone for around $75.
Old Sep 14, 2008 | 05:16 PM
truenoboy's Avatar
truenoboy
Thanks! By the way, I drive a 300, so no V8. Answer me this though....shouldn't the hammering thing work on a failing starter? Last time I had starter issues, I hammered the starter and the car turned over and fired right up. That was in Dec. The metal contact in the starter was warn and burned out, so I changed it with another one (though used), and put back in the same starter. Worked like a charm. I doubt the contact could be warn again, but who knows. It hasn't even been a year yet.
Old Sep 14, 2008 | 05:20 PM
kit cat's Avatar
kit cat
sounds like your starter, mine started to act up last year around this time.
edit: nm, you drive a GS300.
Old Sep 14, 2008 | 05:29 PM
JeffTsai's Avatar
JeffTsai
For us GS300 folks...we have it easy. The starter is decently easy to change out. I can do it in about 30 minutes or so.
Old Sep 14, 2008 | 07:08 PM
gsCrazy's Avatar
gsCrazy
i think it's your started. mine did the same thing last winter... i would go turn the key and it would click once. i would then have to turn it a few more times; with each successive time i would hear more clicks until it finally starts after the 4th or 5th turn.
i got it replaced and all has been fine since.
ca13815
Sep 5, 2014 11:45 AM
andyman32
24
Mar 20, 2012 05:55 AM
LuxOut003
Oct 29, 2008 05:36 PM
lexus1125
RX - 1st Gen (1999-2003)
Mar 25, 2008 12:10 PM
nmarcks
Sep 15, 2003 11:27 AM
