Cig lighter/accessory outlet doesn't work
The one inside the glove box works fine, but the one in the ash tray doesn't work. I've checked the fuse, and it is fine.
Any thoughts? |
Originally Posted by Bentley1
(Post 3729123)
Any thoughts? |
Originally Posted by GS_OREO
(Post 3729253)
Check fuses :thumbup:
Ok, I found the problem. I had to take the whole assembly out: put on parking brake, move key to acc, move gear to 2L, and then just gently pull the whole assembly out. I then had to take the thing apart and get to the bolt that holds the back of the sig assembly together. I inscrewed that, took everything apart, and then put it back together. It works now. Something must have come loose.
(Post 3729376)
| All times are GMT -7. The time now is 06:23 AM. |
