Shakes while Idle?
Old Oct 30, 2008 | 03:42 PM
  #31
Adam2562's Avatar
Adam2562
motor mounts.... motor mounts..... motor mounts......
Old Oct 31, 2008 | 12:30 AM
  #32
GS4_Fiend's Avatar
GS4_Fiend
the lexus gs 300/400 doesnt have an EGR valve
Old Oct 31, 2008 | 12:34 AM
  #33
GS4_Fiend's Avatar
GS4_Fiend
they both are aluminum block... its domestic that uses iron block
Old Oct 31, 2008 | 01:15 AM
  #34
macd7919's Avatar
macd7919
Actually, you are 100% wrong. Late model U.S. cars are legally required to have an EGR (Exhaust Gas Recirculation) valve for emissions.
Obviously from the above statements you have never worked on either car. I'll give you $5000 when you find me a factory aluminum 2jz. Out of the 25+ 2jz motors I've built, amazingly not one has been an aluminum block. Good luck searching.
Old Oct 31, 2008 | 02:08 PM
  #35
Adam2562's Avatar
Adam2562
lol is all i have to say
Old Oct 31, 2008 | 02:11 PM
  #36
lexusscturbo's Avatar
lexusscturbo
Seafoam it
Old Oct 31, 2008 | 02:18 PM
  #37
Adam2562's Avatar
Adam2562
lol i seafoamed my GS.. it threw the CEL on but i just disconnected and reconnected the battery and it hasnt ever come back on.... i seafoamed my 93 honda too and i actually get 50miles per tank more every single time now the gs has improved mileage by maybe 1mpg the **** really works.. i used it on my fathers 97 avalon too and that things runs strong
Old Nov 1, 2008 | 11:11 PM
  #38
GS4_Fiend's Avatar
GS4_Fiend
Well usually imports they use aluminum block. But about your saying about " Late model U.S. cars are legally required to have an EGR (Exhaust Gas Recirculation) valve for emissions." is not 100% true. Because they use valve overlapping which is also known as the VVT-i to control the valve timing so EGR is not necessary to have. Also the old gs300/gs400 has egr true, but the 1998 and up does not have one i can gurantee you that either one gs300 or 400.
Old Dec 11, 2008 | 09:51 PM
  #39
ak11's Avatar
ak11
You don't need to spend $129on having your fuel injectors cleaned, go to an auto parts store and buy the fuel injector cleaner made by Lucas. Purchase the big bottle and run it through every time you fill up the car for as long as it lasts (probably 5 or 6 full tanks) that will work just fine.
I bought a big Lucus bottle and pour 8 fl oz in a full tank for 1 time.
I have about 25% "Shakes when Idle" now! Maybe the A/C have something to do with it during summer! I will try it a few times!
Originally Posted by lexusscturbo
Seafoam it
I bought a SeaFoam also too, but afraid to use it, my mechanic said it may clog my O2 sensor...(I may ask my mechanic to take out the O2 sensors and seaform it)
Old Dec 11, 2008 | 11:18 PM
  #40
Adam2562's Avatar
Adam2562
i seafoamed my GS4.. it threw a cel light after but all i did on that and my fathers vaalon was disconnect neg cable for 30 min and it was gone and has never came back.. been about 8k
cpone
Dec 1, 2008 10:42 PM
3000
Jan 31, 2006 11:29 PM
Hit Man X
Maintenance
Jul 13, 2005 08:55 AM
mrshabo
Jul 5, 2003 02:45 PM
ES3
Maintenance
Feb 2, 2003 06:10 AM
