problem about the speed drop ???
Old Jun 23, 2008 | 11:49 AM
e-low's Avatar
e-low
Default problem about the speed drop ???
sup guy i have a 01 gs430. i was on the freeway go 65 mph about 2200 rpm than my speed just drop and my car feel like it losing power. than i punch on the gas than it go back to normal again. This happen to me a few time already. So i wonder could you guy help me out.
Thank you
Old Jun 23, 2008 | 11:58 AM
Solo_D33A's Avatar
Solo_D33A
I had same problem as well, don't know why, but only on highway cruising speeds...
Old Jun 23, 2008 | 01:11 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
So all of the sudden you lose power at highway speeds with the accelerator depressed?
Old Jun 23, 2008 | 02:07 PM
chuckb's Avatar
chuckb
maybe maf or tps?
Old Jun 23, 2008 | 02:49 PM
Solo_D33A's Avatar
Solo_D33A
Yeah when cruising at speed, accel at same level.
it's possible for maf or tps, but it only occurs when cruising for about the same speed and mostly if not all only at highway speeds...
Old Jun 23, 2008 | 07:11 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
In that case, im not sure. Does the 430 even have a TPS sensor?
Check the TSB's for that model year.
Old Jun 23, 2008 | 07:36 PM
GS FONZy's Avatar
GS FONZy
Check your battery terminals, make sure they are not loose. It can also be the fuel pump.
Old Jun 23, 2008 | 07:48 PM
Solo_D33A's Avatar
Solo_D33A
I don't think it's battery as alt will still provide power, I've had the terminal loose before, there's no signs for that problem until you try to start the car.
Old Jun 24, 2008 | 10:40 AM
e-low's Avatar
e-low
yeah i think it the fuel pump too but i dont want to waste any money on it if it not the problem.
cenozoite
Jan 30, 2018 11:56 AM
Mr.Gs_GTE
GS - 1st Gen (1993-1997)
May 25, 2015 11:52 PM
lexus-is2
Apr 15, 2013 07:43 AM
sleeperGS
Dec 5, 2008 05:57 PM
chino78
May 24, 2001 03:25 PM
