Usual GS MPGs?
Old Apr 18, 2008 | 04:30 PM
Billh2's Avatar
Billh2
I get 19 to 20 around town. "Town" being 7 mile highway drive from my house to get to town. Depending on how I drive on the highway, mileage can be as low as 22, (Eastern Oregon state, 50+ miles of straight road, no traffic and cruising at 110 MPH) to as much as 26 driving 65. At my usual cruising speed, which is the posted limit +5 MPH, I get 24 to 25 at 75 MPH.
Your mileage may vary
Old Apr 18, 2008 | 05:02 PM
PushinLEX's Avatar
PushinLEX
I ALWAYS get 20+ MPG.................
Old Apr 18, 2008 | 07:02 PM
Hectorm's Avatar
Hectorm
Wondering how you guys takes the MPG of your car...
Mine GS4 never go over 17.3 combined, driving with measure and 60-70% highway. (new SPlugs and throttle cleaning)
My wife car Lexus ES300 (2003 with 46k mi) is around 20-22 (6cyl) My Integra 93' 24mpg (4cyl 1.8)
The new 2008 Scion is 27.5 (combined) real life, rated by Edmund's
How is possible that you get 22 in city... or 27 in HW??? Are reading the computer readings??
The correct way is filling the tk, reset the odometer to 000, run the car as always and when filling again taking the odometer reading and divided by gals from the pump. This will give you the correct mpg.
Is your GS4 are giving more than 20 combined, your car needs a very exhausted revision to be share between us. We gladly want to know how to obtain more MPG to overcome a little this energy crisis.
Old Apr 18, 2008 | 07:53 PM
litesoarer's Avatar
litesoarer
Cruise control on highway, and snow mode in the city, and coasting whenever you can.
Yes, this is what i do, in fact. i round down if it comes out to say 22.1 - 22mpg.
Well...i do have the stock PS 16's And low rolling resistance tires (Pilot HX MXM4)
Simple, SLOW DOWN.
It also depends on the terrain where you live, if there's a lot of hills don't expect to consistently get 20+mpg all in-town, the kind of gas being served in your area. Altitude is also important.
Old Apr 18, 2008 | 08:18 PM
BCP43002's Avatar
BCP43002
I get 22.5 with 90% highway with my 430.
Old May 11, 2008 | 10:06 AM
litesoarer's Avatar
litesoarer
New record for GS4! (Maybe)
Just did 340 miles on 12.6gal (27mpg)
The first 145 were all highway, next 195 were 70 city/30 hwy
or about 58hwy/42city for the tank
This was achieved using non-ethanol blend 92 octane premium, about to see how we do on 10% ethanol 93 octane
Old May 11, 2008 | 05:45 PM
Mike813's Avatar
Mike813
16.75 MPG with 10% ethanol mixed premium fuel. All city driving, 30psi tires, cleaned MAF,cleaned TB,fresh oil + tranny fluid, clean oem air filter. i can def. see higher range if i drive highway mix miles or highway alone.
Old May 11, 2008 | 10:00 PM
litesoarer's Avatar
litesoarer
30psi in the tires is your problem there.
mine are in the 38psi range, and when hot are ~40psi give or take
I also do a lot of pulse and glide, and in general, driving like my brakes are out. (Relax, they aren't)
Following the speed limit helps tremendously.
Old May 12, 2008 | 12:16 PM
sleeper408's Avatar
sleeper408
Since I cleaned the MAF and air filter, I've been getting about 23MPG/Mixed. That's 360 miles off a full tank (16.xx gallons).
Old May 12, 2008 | 06:17 PM
Mike813's Avatar
Mike813
30 Psi is recommended tire pressure for my size tire, i have oem 16's.
Old May 13, 2008 | 06:23 AM
DetMich1's Avatar
DetMich1
30 PSI will give a very soft and comfortable ride, however with higher pressure (still within tire manufacturer's specs) you will achieve lower rolling resistance, longer tire wear, and better mpg. You will sacrifice a small amount of ride quality but gain more than you lose in the improvements in the other parameters.
Old May 13, 2008 | 08:11 AM
Mike813's Avatar
Mike813
good to know, i need to air up a bit more on the next gas run on both the vehicles. i always went by oem recommended.
nmlexus4gs
Oct 25, 2017 06:35 PM
mrfuni
Feb 18, 2014 09:44 PM
abbeyrd
Aug 20, 2012 07:45 PM
sparky3
Nov 16, 2010 10:45 PM
94Supra
Sep 16, 2010 12:47 PM
