Need help with sparkplug problem
Old Mar 9, 2008 | 09:14 PM
VAgs430's Avatar
VAgs430
Default Need help with sparkplug problem
I RECENTLY CHANGED THE PLUGS ON MY 01 430 AND REALIZED THAT FOR SOME REASON I HAD A HUGE POWER DECREASE. IT SEEMS THAT I HAVE A VERY NOTICIBALE POWER DECREASE AFTER 3500RPM. BASICALLLY THE MOTOR HESITATES TO ACCELERATE AND THE ACCELERATION IS NOT SMOOTH AT ALL LIKE BEFORE THE PROBLEM AROSE
i PUT IN SOME NGK IRIDIUM PLUGS WHICH HAVE AN IRIDIUM CENTER ELECTRODE BUT A PLATINUM SIDE ELECTRODE. i KNOW THAT THE MANUAL STATES THAT YOU SHOULD ONLY USE IRIDIUM PLUGS BUT THIS IS ALL THAT THEY HAD AT THE PARTS SHOP. COULD THIS BE THE PROBLEM
A BUDDY OF MINE ALSO TOLD ME THAT THE GAP ON THE PLUGS ALSO MAY BE OFF?
IS THERE A SPECIFIC AMOUNT THAT THEY HAVE TO BE TORQUED TOO?
IF ANY ONE COULD OFFER ME ANY SUGGESTIONS I WOULD APPRECIATE IT.
Old Mar 9, 2008 | 09:46 PM
GSteg's Avatar
GSteg
The iridium part is the center electrode. When given the name, copper, platinum, iridium, etc, they are referring to the center electrode.
It should be pre-gapped from the factory so you shouldn't even have to touch it.
Torque spec is 13.5-14ftlbs
Old Mar 9, 2008 | 11:50 PM
VAgs430's Avatar
VAgs430
thanks gsteg...
so if i am using the right plug and the gap is correct why am i having this huge powerloss?
could it be that the plugs arent torqued?
could the guy at the parts shop gave me the wrong plugs?
i am about to settle for some torque master plugs and see if that helps but horefully i wont have too.
http://www.l-tunedparts.com/product/?id=1779
does n e one else know why this may be happening
Old Mar 9, 2008 | 11:57 PM
GSteg's Avatar
GSteg
Maybe it's the coils? Check each individual harness for the coil pack to see if they're tightly connected.
Old Mar 10, 2008 | 12:03 AM
VAgs430's Avatar
VAgs430
Thumbs up
thanks for the advice im going to check first thing in the morning n hopefull it'll be fixed...
that sounds like a good solution... hopefully it will fix fix da problem
Old Mar 10, 2008 | 12:45 AM
pitmanr200's Avatar
pitmanr200
im with you. I cant see any other scenario that would cause this other than maybe you broke a plug putting it in. i have done many of spark plug changes on many of cars and some of them i didnt gap and some of them i did and have never had a problem like your talking about. and have never torqued to specs. just tighten them snug. but that is just me.
Old Mar 10, 2008 | 09:24 PM
VAgs430's Avatar
VAgs430
unfortunately it was raining today so i didnt have a chance to check ...
is there any way i can check which cylinder is having the problem?
also it seems odd to me that there is no check engine light coming on? One time a notice did pop up on the NAV screen that said "service take to nearest dealer" but i wasnt sure if that wass for scheduled maintinence since the car was nearing 100k. it popped up during the test drive after the install. i have a scanner but the car doesnt seem to be throwing any codes.
Old Mar 11, 2008 | 10:03 AM
VAgs430's Avatar
VAgs430
i finally got the chance this morning and checked each individual sparkplug. i retightened all of them finding that 2 were a little loose. i also checked all the wires. it did help somewhat but the car still struggles to reach high RPM's. It seems that the car is either running lean or rich i cant tell. if im cruising at 50 or 60 and get on it i will hear a pop which im guessing is a cylendar backfiring. Basically i jst popped the cable off to reset the ECU hopefully that will solve my problem
if not im going to have to settle for going to a dealer to see what the problem is... hopefully i wont have too because they wanted to charge me over $400 to change just the plugs and no wires.
Old Mar 11, 2008 | 09:32 PM
VAgs430's Avatar
VAgs430
I reflashed the ECU and it was a world of a difference...
my gs is back to life
it still feels like it has a little lag around 3-4k rpm but i think the ecu is adjusting
THANKS FOR ALL THE HELP
PhreshhWun
Sep 12, 2011 04:35 PM
CBRA928
Aug 10, 2010 01:57 PM
CAMAracer
Nov 18, 2009 09:47 AM
tommyGS3
Performance
May 14, 2009 04:18 PM
mlevk
12
Nov 22, 2003 01:53 AM
