Rays G35 FORGED 19 inch wheels on GS pics
#136
I will measure and post up pics so that everyone can see. But I was using Kics R40 conical seat lug nuts for my wheels since the is the correct type of nut to use. The g35s use a concial or acorn lug nut sotck so if you were to look inside the bolt hole you would see that they are not totally flat. The mag stly lug nuts which the gs uses basically all that is holding you wheel on is the tip of the lug nut since it doesnt go into the bolt holes. On the stock gs wheels the bolt holes are wider so the lip of the lug nut rest on the base of the bolt hole. Determintal or not I dont know as I have let a friend of mine use my wheels and he used the stock lug nuts, but I would be too paranoid to have all that force sitting on an aluminum lip that is less than a quarter inch thick.
#137
255 is the larges tire you can use on a 8.5 width. As far as upgrading wheels, that 255 should work on my 19x11
#138
hubring. http://www.1010tires.com/hubrings.asp
buy the aluminium. 60.1 GS and 66.1
description on that site:
66.06 mm 60.1 mm Aluminum $27.99
The Stock lugs are conical (unless I have an aftermarket one). Anyways...I just replaced it with r40 last week. Both will do the job...but yeah, you can just go to a local parts store and buy'm.
#142
^ yep...look at oem...it does have conical shape to it. It would serve the purpose I suppose.
Anyone looking for this -I wouldn't spend the money on them kics though...just get one from local autoshop - unless the vendors here can provide it for cheap (it doesn't have to be the one shown above - you can get cheaper ones of the same conical type).
#144
ok so since im fixing to aquire some g35 19"...without re-reading 10 pages (yeah im being lazy i just got back from vacation) i will need the following...nething else?
hubrings
15 mm spacers BOTH front and rear?
and conical lugs....what size threading?
nething else im gonna need to just slap these on? besides alignment, coilovers or some shocks/springs?
hubrings
#147
hubrings
hubrings
