Clunking noise from passenger
Well, I know this issues been way way played out,but i solved my problem and need to know where i could get these parts? I need to know what's the part that holds the front brake rotors to the hub bolts so it does not move around. The thing that i noticed is that i took out the front tire to inspect and i noticed that when i was wiggling the rotor back&forth the rotor had some play in it. I know there is some kind of shim/sleeve that goes over the hub wheel bolt after when u install the rotors on there so it does not move. What is that part? And where can i get them?
diamondmit
Suspension and Brakes
Jun 6, 2007 05:42 AM
