Are wheel spacers worth it?
Subscribe
Jul 8, 2007 | 08:25 PM
Reply 0
Jul 8, 2007 | 08:38 PM
Quote:
LexusKid, why do u say no-no to the spacers? I spent a lot of time a couple of days ago in the Wheels & Tire Forum and there were a lot of folks who agreed with having spacers.
Reply 0
Jul 8, 2007 | 11:13 PM
Quote: i run spacer/adapters on both of my cars, and have for thousands of miles, and several cross country road trips.
never a SINGLE problem.
yup. if you're having issues you're either not running hubcentric good quality spacers (like H&R) or you bolted them up incorrectly..
heres a pic of the 25mm H&R rear spacers on the 430. i cant believe lexus even let the car come out of the factory with the obnoxious pushed in stance it has stock. bad lexus, bad!
no spacers (bad!):
25mm spacers in the rear (good!):
Reply 0
Jul 8, 2007 | 11:16 PM
Quote: Take the spacers off imedietly i will explain why i ordered Nice rims for my 06 Ls-430 UL and they have been nothing but a nightmare i installed 6mm hubcentric spacers and hubcentric rings took evrey precaution i could with the spacers and am still not pleased with the result i have even had the lexus service center take them off put them onn align them and balance them and they handle like crap compared to the stock 18's that came with the car as of right now i am looking to buy new tires for them to try and make the ride a little better and am buying brembo calipers so they will fit right on without spacers in the meantime im saving up and doing reasearch to buy new rims. This is only from my experience and i know the ls and gs are diffrent cars but im just trying to save you from making the same mistake i did.
you cant just go telling people to "take the spacers off immediately" so they freak out man.. just because you had a bad experience doesn't mean its going to happen to everyone... ive been using the h&r 25mm spacers for weeks and have zero complaints about them. there is no shake and no problems whether im doing 30 or 120.
Reply 0
Jul 9, 2007 | 02:53 AM
that's it ready to buy these, Q: should I buy the 20mm or 25mm instead? I have the stock 17" 245/45/17 don't want to put any up front just the rear!! i where's the best deal out there for these H&R.
Reply 0
Jul 9, 2007 | 02:56 AM
Quote: that's it ready to buy these, Q: should I buy the 20mm or 25mm instead? I have the stock 17" 245/45/17 don't want to put any up front just the rear!! i where's the best deal out there for these H&R.
cant tell you where the best deal is, but go with the 25mm h&r. look at the pic i posted. i have the same size wheels with the 25mm spacer in the rear and nothing in the front. it looks great and its still not sticking out too far. you'll be very happy with them. trust me
Reply 0
Jul 9, 2007 | 06:35 AM
Quote: yup. if you're having issues you're either not running hubcentric good quality spacers (like H&R) or you bolted them up incorrectly..
It does look better
Next wheels I'm looking at are 18x8.5. I think 25mm spacers are doable for that wheel width w/o poking out beyond the fender
Reply 0
Jul 9, 2007 | 09:00 AM
I have had no problem with my h&r 15 front and 25 rears. I would definitely do the front too so the wheels are evenly spaced.(pic below) Just doing the rears doesnt look right to me. I guess it depends on your taste.
Reply 0
Jul 9, 2007 | 10:59 PM
Guys, what are you doing about lug bolt length? Are you adding longer studs so the lug nuts will still bolt on after adding the spacers?
I've got 18x8.5 Lexus G-Spider wheels. I'm thinking about 15 or 20 mm spacers. Will that work? Will I need to add longer lug bolts?
Reply 0
Jul 9, 2007 | 11:50 PM
Quote: Guys, what are you doing about lug bolt length? Are you adding longer studs so the lug nuts will still bolt on after adding the spacers?
I've got the same wheel as you and I'm running 15mm spacers. The H&R come with longer wheel studs, so you will have to replace your existing ones.
Reply 0
Jul 10, 2007 | 09:30 AM
I posted a picture in the page before so it can answer you question about different spacers and bolts
Reply 0
Jul 10, 2007 | 10:10 PM
the 25mm h&r spacer for the rear bolts to your existing studs with included nuts. you then re-use your stock lug nuts to attach your wheels to the new studs built into the spacer...
here look:
thats what comes in the kit.
Reply 0
Jul 11, 2007 | 06:10 AM
no spacers (bad!):
that looks perfect. what springs are you sittin on? im lookin for that ride heigh with stock wheels.
Reply 0
Jul 24, 2007 | 07:26 AM
upstategs4,
I wanted to go with 15mm front 25mm rear h&r, I found a website and they give you an option of DRS type for front and DRM type for rear, as you know h&r has 4 different types, does that sound good or they need to be the same type? what type did you guys get them in and where? shoot me a PM if you don't mind. thank you
Reply 0
Jul 24, 2007 | 09:44 AM
will that work with 20's , i notice all of yall are doing it with the stock wheels, and if it does work with 20's will tthere be any vibration or shaking at 60-80 mph
Reply 0
