Tom's Mirror Covers - wiring question
For those of you that has ever installed it...how did you wire it? Just tapped it into the existing turn signal wiring? Did you have to install relays? Etc....
You can tap into the turn signal wiring behind your dash cluster or run wires to your turn signal bulb. The rear turn signal bulb is a longer distance, but it's a bit easier to run wire to the rear bulbs than the front.
No relay required, as the LEDs draw too low of a current to require a relay.
