airbag light code 73 and 63
need some help/ advice here fellas.
i swapped out my seatbelts for some new ones and after the swap my airbag light came on flashing.
i tried the procedure that i found using the search function thinking it was triggered cos of the swap.
i hooked two wires to the Ts and AB and proceeded with the "wire dance"
.Ts,ab,ts, ab,then ts held down to ground.
i noticed that when i touched the TS to ground , the light would stop flashing for a few seconds and then flash 7 times and then 3 times and pause and then then 6 times and 3 times again.
does this indicate codes 73 and 63?
can anybody tell me what these codes are and can the "wire dance " clear the light?(if i do it correctly)
.Ts,ab,ts, ab,then ts held down to ground.i noticed that when i touched the TS to ground , the light would stop flashing for a few seconds and then flash 7 times and then 3 times and pause and then then 6 times and 3 times again.
