ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   GS - 2nd Gen (1998-2005) (https://www.clublexus.com/forums/gs-2nd-gen-1998-2005-184/)
-   -   Driver seat won't move (https://www.clublexus.com/forums/gs-2nd-gen-1998-2005/208357-driver-seat-wont-move.html)
asci01 Mar 27, 2006 06:17 PM
My driver seat won't move back and forth but it moves up and down. When I press the button to move back or forward I hear a click coming from the motor so I know is getting power.
Anybody has any idea what it could be?
Any help is appreciated
asci01 Mar 28, 2006 07:09 PM
Help!
Anybody encountered this before?
rgarjr Mar 28, 2006 07:50 PM
Maybe its jammed up against something..
asci01 Mar 29, 2006 05:58 PM
I sure would hope so. I new motor is over $350.00 :eek3:
I have tried pushing the seat while pressing the button but no luck.
Any suggestions on how to test whether is a bad motor or a jammed seat?
rgarjr Mar 29, 2006 06:04 PM
I would probably take out the seat and flip it upside down and check it...
asci01 Mar 29, 2006 07:22 PM
1 Attachment(s)
I did. The motor is the one on the top left corner but I have no idea how to take it out or test it
Any suggestions?
Does anyone have the diagram to take the guts of the seat apart?
asci01 Mar 31, 2006 07:33 PM
Am I the only one with this problem? :uh:
Has anyone encountered this before?
JeffTsai Mar 31, 2006 11:21 PM
Are you sure you didnt:
A) Blow the fuse
B) Have a loose wire loose inside the seat (connection to motor)
C) Harness from floor to seat is broken
asci01 Apr 1, 2006 07:54 AM
A) Blow the fuse
When I push the button to move it back or forth the motor makes a click and sounds like it wants to move the seat. So I'm sure it is getting power. Could the motor be bad even tough it sounds like it is trying to move the seat?
BLW Apr 2, 2006 07:40 AM
Guess?
1 Attachment(s)
I do not for know 100% for sure that this will solve your problem and I have not had this problem with my power seats, but here is my guess. I am guessing that the motor needs to be taken apart and have the dust from the motor brushes cleaned out from the interior of the motor. I had problems with the tilt function on my steering wheel and cleaned out the the brush dust on the motor for this function and everything works again. The motors look to be of similiar design with no venting and nowhere for this dust to escape the interior of the motor. If you can figure out a way to remove the motor so that you can diassemble it and clean it out and relube it you may get the motor to function properly. Here is a link to the power steering wheel tilt issue:
https://www.clublexus.com/forums/sho...d.php?t=104571
If you can get the white cap, where the motor brushes are located internally (left side of motor) seperated from the metal housing of the motor, the brush dust could be cleaned out and hopefully restore function to the motor.
asci01 Apr 2, 2006 10:38 AM
Hey thanks, BLW. The steering wheel motor looks just like the seat motor. So maybe I can fix it the same way you fixed yours.
So I just blow the dust out, remove the old grease, and re-grease with fresh grease, right?
BLW Apr 2, 2006 01:20 PM
Pretty much , Yes. I also took an old toothbrush and cleaned up the dust and blew out the dust. The grease is actually at the oppssite end of the motor than the brushes. The grease side is at the rear end of the metal motor housing while the brushes are in the white plastic end if it's like the tilt motor. Let us know how things turn out.
By the way. the larger motor photo insert is just a larger view of the seat motor to show where the brushes should be located. It is not the steering wheel tilt motor. I did not take any photos of the tilt motor.
asci01 Apr 2, 2006 02:01 PM
So does the new grease goes inside or outside the motor?
BLW Apr 2, 2006 03:24 PM
Worry about the dust more than the grease. I have never disassembled the seat motor only the tilt motor. You should see where to apply grease ( if necesarry) from where the original factory grease is. Have you been able to disassemble the motor?
asci01 Apr 2, 2006 04:06 PM
No yet. First I have to figure out how to take it out of the bottom of the seat. It looked intimidating, but I need to do it soon! The seat is stocked all the way back, so I feel like I'm driving from the back seat :sad:
It's driving me nuts !
