Remote on Key has bad range?
Old 09-28-05, 06:58 PM
JeffTsai
JeffTsai's Avatar
Well as for changing the battery yes its that easy. Once you take the screw out slide the cover downwards first then it should pop upwards. I was messing with it for 20 mins trying to pry it open before I realized that I had to slide it down first
I'm not sure if a new battery is going to fix my short range problem. I got my car new off the lot 3 months ago so the batteries in the keys should still be fresh. My maximum range is around 25ft.
Old 09-28-05, 08:40 PM
rominl
exclusive matchup
rominl's Avatar
in my case the battery is definitley not the issue so...
Old 10-01-05, 12:08 PM
jlexluna
jlexluna's Avatar
i changed my batterries to my remote key and now its worse ! and to make matters worse, when i put it back together it doesnt wanna work either. but if its taken apart it lights up fine and works. but when i put it back together with a new battery it back to same crapy not wanting to turn on and having to stand right nest to my car. and then i have to keep pressing it so it can work............. does anybody know whats going on????
Old 10-01-05, 10:05 PM
JeffTsai
JeffTsai's Avatar
You might of jacked up the antenna or something. The circuitry inside the casing is pretty delicate. Or did you use the correct size battery? If its too small it might just be bouncing around in there and gettin contact 50% of the time. If you are able to...take the whole thing apart down to the circuit board and make sure no foreign objects are stuck in there. Then reassemble and retry.
Good luck!
Old 10-02-05, 01:54 AM
tommyLS460
tommyLS460's Avatar
yeah...i've been having that problem lately too...i would press it and expect to hear a beep...but it wouldn't..and then i would need to walk closer to my car and watch the light to make sure it's activated...i just think it's the battery...need me a new battery soon...
Old 10-02-05, 03:51 AM
REV-01
REV-01's Avatar
sucks for owners who bought the remote starter kit from luxury mods. what is the point of doing remote starter if the stock remote range is only about 100 feet....
Old 10-02-05, 02:24 PM
tommyLS460
tommyLS460's Avatar
i really think it's not a big deal...i mean...aren't u gonna approach the car anyway?...so why don't just wait until u get to the car...lolz..ahha....or when u leave...press it right when u close ur door...lolz...
Old 10-02-05, 04:00 PM
GS Kid 300
GS Kid 300's Avatar
I get pretty decent range on with my remote.. i always hit the unlock button at around 5 car spaces away from my car.
Old 10-02-05, 06:38 PM
rominl
exclusive matchup
rominl's Avatar
thanks man, that's really encouraging
btw, it's luxurymotorworks
Old 10-02-05, 06:57 PM
jlexluna
jlexluna's Avatar
thanx man i appreciate that..
Old 10-02-05, 07:55 PM
REV-01
REV-01's Avatar
sup henry, i just want to keep it real....
the purpose of the remote starter is to start the vehicle, cool or heat up the vehicle before we get in. very useful in extreme cold weather where you can start the car while you are at your office or home
tell me how cold/hot your interior is going to be when you can only started it from 5 cars away versus starting after getting in.....not much
the factory alarm's range is okay for keyless entry, not for remote starter....
Old 10-03-05, 03:04 PM
rominl
exclusive matchup
rominl's Avatar
haha i know man, i was just kidding
to be honest i got the autostart for my car mostly for the cool factor, i know what you mean about being hot though, but since my car usually cools down relatively fast (thank god i don't live in las vegas or hawaii, lol), so far it's been ok
and still, i think it's just somehow the gs remote sux for some yrs..... my sc430 i got auto top down and autostart, i can do that from way far away, easily 200 ft. i was inside the dealership and put down the top to scare the two people wondering around my car.
Old 10-03-05, 03:48 PM
Tranman
Registered User
Tranman's Avatar
I have bad range on mine....heck, it's downright horrible when my Xbox is on (turns off 45 seconds after accessory is turned off). I have to be like 5 ft away to get a response...I guess the Xbox produces some strong EF interference.
Old 12-15-05, 05:41 PM
kkeppler
kkeppler's Avatar
I just opened up my case, the battery is a CR1616, these are smaller then a 2025
Old 12-19-05, 02:10 PM
ocean350
ocean350's Avatar
tried the 'chin' trick after my lunch today.
worked like a charm.
dont understand why does the chin matter....but it WORKS.
i was standing about 45ft away,
Quick Reply: Remote on Key has bad range?
