Hood adjustment
Old Mar 10, 2025 | 06:56 AM
Louielace6's Avatar
Louielace6
Default Hood adjustment
It seems like my driver side does not sit flush & adjusting the rubber bump stop doesn’t fix the issue
It feels like it’s loose around the release hook a bit
Can I adjust that or can it be something else?
Thanks Everyone
Old Mar 10, 2025 | 11:53 AM
dwoods801's Avatar
dwoods801
The hood catch mechanism can be adjusted, it’s going to hold the front edge of the hood in tension, and the rubber bumpers int the front corners set the fender gap. There is also some adjustment in the hinges, the fenders can also be adjusted a little bit, and even shimmed if there is something really wrong.
If one of the front corners is just a little low, then you should be able to resolve it with the rubber bump stops. I am sure YouTube will have some DIY videos to show you how to properly adjust the latch and hinges if you need some guidance
alillo
Dec 23, 2024 03:59 PM
ROSCOGX470
GX - 1st Gen (2003-2009)
Jul 13, 2021 02:51 PM
YODAONE
Sep 23, 2020 02:47 PM
StanleyR
Mar 6, 2019 07:43 PM
macsta
Mar 24, 2009 02:55 AM
