Pulling/ rolling arches
Subscribe
Oct 2, 2024 | 09:56 AM
Hi there all, quick question, has anyone ever pulled their front arches to the extent I might have to to fit these wheels, if so pics would be a wicked as well as any advice, really like these wheels and really hope I can get them to fit, currently at about -6 degrees camber on the front which has brought them in slightly, does anyone think it’s doable or over fenders is the best bet
Reply 0
Oct 2, 2024 | 11:12 AM
Honestly the answer to that question depends on the amount of poke you will be happy with
Reply 0
Oct 2, 2024 | 08:39 PM
There isn't enough material to cover the amount of poke you currently have. Ulterior Motives makes fender flares for the GS that are a subtle alternative to big Serial Nine or N-Style fenders.
Reply 0
Oct 3, 2024 | 12:47 AM
Have you looked at adjustable upper control arms? There are some that can alter the camber up to 6 degrees. The factory lower control arms can be adjusted a couple degrees and that should also help you out a little bit. That plus shaving the lip off the fender and then you can roll it and they will flare out a little bit. Do you not like how these rims fit? Or have you gotten a ticket or something? Your best option would probably be to sell this rims and replace them with a set that have less offset.if you do all this other work it can get expensive, and these rims will probably never tuck up tight into the fender as well as a set with the ideal width and offset.
Reply 0
Subscribe
