Door lock problem
Old Dec 21, 2023 | 01:42 PM
moshah123's Avatar
moshah123
Default Door lock problem
Hello, I have a 98 GS400, and when I turn use the key manually in the driver door. It used to lock and unlock fine and that’s how I used it since my actuators were bad. Now that I replaced them and all has been good except I just tried to use the key manually and the key goes in but dosent do anything. It just turns left and right without any resistance or noise or any attempt to unlock the door. Anyone know what the problem is?
Will attach a video.
thanks.
Old Dec 21, 2023 | 01:51 PM
Gerf's Avatar
Gerf
Something wasn't re connected. Do the doors unlock with the fob buttons?
Old Dec 21, 2023 | 02:52 PM
moshah123's Avatar
moshah123
yea. I changed the actuators like 2 months ago and the key lock worked fine. I think I used it.
Old Dec 22, 2023 | 05:22 AM
McPierson's Avatar
McPierson
Does the inside lock toggle work?
if it’s just the outside key the rod has come loose, possibly the plastic retainer is broken.
Door panel off.
Old Dec 26, 2023 | 08:58 AM
moshah123's Avatar
moshah123
Door panel off.
inside lock works. I’m not saying I did… but when I took off the handle… I may or may not have loosened the wrong screw… and broke something off on accident. May be that…
Old Dec 26, 2023 | 08:30 PM
McPierson's Avatar
McPierson
The key tumbler has a plastic retainer for the lock rod and that retainer may have broken. You could probably order just the retainer. You could probably redneck something up to.
Pos300
Jun 9, 2015 01:36 PM
Joeyc850
Mar 14, 2015 07:51 AM
pirate2050
Jan 12, 2014 09:42 AM
mvbls400
Feb 12, 2012 08:19 PM
shkani04
Mar 4, 2009 01:24 PM
