Radiator flush
I just did a timing belt,water pump, serp,etc... Is there a bleed valve on the head somewhere or does it self bleed with the engine running and rad cap off ?
Thanks |
drain cock's on the bottom of the radiator.
Yea I about the drain cock thats how I drained it but now filling it back up I ran the engine to normal temp with the heater on to fill the heater core and it kept drinking and drinking and I cant seem to get all the air out of the system :(
You should be able to just fill it up, then run the car with the heater on and the radiator cap off until you get all the air out.
