How hot does your GS300 run?
Old 11-04-14, 03:06 PM
sabbates
sabbates's Avatar
Default How hot does your GS300 run?
I've got a 94 GS 300, and I noticed that the temperature gauge never goes more than a third of the way up.
Is this normal?
The cars I've had in the past sit at half way up the temperature gauge, so this looks strange to me.
Should I check to see if the thermostat has been removed?
Old 11-04-14, 03:55 PM
joewitafro
joewitafro's Avatar
Mine sits half way up. Replacing the thermostat sounds like cheap easy maintenance for sure.
Old 11-04-14, 04:35 PM
TRACKMKIII
TRACKMKIII's Avatar
Yeah mine runs slightly below the half mark.
Old 11-04-14, 05:01 PM
onelt1
onelt1's Avatar
And mine sits just above half way.
Old 11-05-14, 04:04 PM
93aristogs
93aristogs's Avatar
Change the thermostat and have the system bled
Old 12-15-14, 05:01 PM
CARSNBIKES
CARSNBIKES's Avatar
I also run just a shade above the halfway mark, I can barely see white under the needle.
Old 12-31-14, 04:57 PM
Titten
Titten's Avatar
Mine runs 2/3 of the way p. Im thinking rodding or replacing the radiator will make it run cooler. Maybe.
Old 01-01-15, 07:01 PM
forcefed44
forcefed44's Avatar
Mine runs slightly below the mid point on the temperature gauge, once in a blue it drops down an 1/8"
Old 01-05-15, 10:57 AM
sabbates
sabbates's Avatar
I replaced the thermostat, now the temp is half way up the gauge.
Old 01-18-15, 10:22 AM
projectgs1
projectgs1's Avatar
How do you bleed the cooling system?
Old 01-18-15, 02:04 PM
TRACKMKIII
TRACKMKIII's Avatar
Here is a quick video I find on youtube.com it is a pretty easy process. Burping The Cooling System "How To":
Old 01-18-15, 03:05 PM
ComponY
ComponY's Avatar
Almost exactly on mid. Not really over or under. Until my radiator blew, then it was way over xD
Old 05-01-17, 02:20 PM
Beraad
Beraad's Avatar
Mine reads very consistently just below halfway. It used to read halfway before I added a bottle of hyperlube when I did my last flush. No known problems
Old 05-19-17, 02:10 AM
SuperStree
SuperStree's Avatar
Yes, it's seems like your thermostat is stuck open and will cycle the coolant through the radiator even when cold.
Old 06-22-17, 01:52 PM
phemobay
phemobay's Avatar
Hello Lexus people,
my GS300 Ignition was changed and the car stated but missed timing
the engineer didnt get the timing right so i hear a sound (kra) whenever i do a sharp rev but when i do a normal rev (slowly) it doesn't make the noice.
note that I dont have anyone with timing light but i have volt metre.
please what are the side effect and the solution
can it knock my engine if drive to a distance place as it is now
Quick Reply: How hot does your GS300 run?
