Door handle swap
Should be just 2 10 or 12mm bolts on the inside. You just have to read into the door frame with the panel off to remove it. Did you check out that link I sent ya on your last page. It'll show you what the door basically looks like with the panel off.
figured it out
Ok guys. To get the clip I needed I had to remove the door handle. To get the handle off you have to remove the window and right side track to access the second 10mm bolt. Then a little elbow grease and that sucker pops rite out!
