Question about the FANS on our cars
i have a 95gs300. there is a total of 3 fans on it. there is the BIG main cooling fan, the MEDIUM sized fan in front of radiator drivers side.... for the codensor????? and then the LITTLE cooling fan right other the other side of the raditor (behind it) on drivers side.
Are ALL 3 fans sappose to be running at ALL times when engine is on????
all 3 run constantly on my car, even if the AC is off. just seems like a lot of running fans.. ????????????????
It is probably running hot. Check to see if your Fan Clutch on the Large fan is loose or if it is tight when you try and move the fan. it should have resistance if the fan-clutch is still in working order.
I had to replace the fans becuase none of them where working to begin with. and now there all working... all the time... i just dont get it... some sort of sensor somewhere i think
400fanboy
13
07-14-18 11:50 AM
