need help with new light mods please
so i bought some led lights that im attaching to my bumper. they came with a rocker switch but i dont wanna install that in my car, how can i tie them into my lights now so they come on whenever my headlights come on? is this possible? it has a ground and power wire but i didnt know what i need to do 2 perform this mod...
any suggestions? do i even make any sense?
Yea you make sense as long as you r not connecting a ton of led to the light circuit you should be ok, if not you can run a dedicated power wire from the battery (with a fuse) and use the switched ground signal from the headlight to activate you may want to put a diode on the switched wire.
