ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   GS - 1st Gen (1993-1997) (https://www.clublexus.com/forums/gs-1st-gen-1993-1997-120/)
-   -   LS400 Break's Facts only! (https://www.clublexus.com/forums/gs-1st-gen-1993-1997/338989-ls400-breaks-facts-only.html)
zazzn Feb 28, 2008 08:42 AM
LS400 Brakes Facts only!
Hi All,
Ok my brake problem has come back and my front stock calipers are sticking again and have wrapped another rotor.
I am now going to upgrade to LS400 calipers/discs.
I need answers to these questions from people who know who.
-Does the caliper need to be ground to fit past the tierod.
-Does can I use 16" rims? LS400's look like they used 16" rims during the production run for the cars during the time these calipers where used.
-Do i need any spacers or anything else?
Thanks!
Seize Feb 28, 2008 09:16 AM
Fellow CL member indypwr successfully did this upgrade a while back. You might want to PM him.
https://www.clublexus.com/forums/sho...t=ls400+brakes
ILOVEGIRLS Feb 28, 2008 09:25 AM
i wouldnt recommend grinding anything. you can use rca's to get the clearance you need.
the rims question, i cannot answer.
Lexiss_sc430 Feb 28, 2008 09:38 AM
[QUOTE=zazzn;3316680]Hi All,
I need answers to these questions from people know who.
-Does the caliper need to be grinded to fit pass the tierod.
Yes, on any 2nd gen GS, sc430 you will need to grind down a few mm's off the end of the LCA bolt and possibly the nut itself. After that, you might even have to grind a little bit of material off of the actual caliper. The reason I use words like might and maybe is that I have seen different cars need more or less grinding, so it’s kinda a case by case basis.
Why dont you just make a LCA bracket? it would lower the LCA by 3/4-1 inch and you can call it a day.
As long as the wheels have adequate back spacing, then you should be OK, wheels from any 95+ LS or Supra TT will fit perfectly. I believe on the stock LS wheels they're offsets are 45-50
If you get the correct wheels/offsets then no. :uh: but if you were to buy a set of wheels that you happen to like and they are a little too close to the calipers then yes you will need to by spacers, and again that depends on how much clearance you will need to compensate for.
Do a search, there is a gs member who has installed them and written up a tutorial.
zazzn Feb 28, 2008 11:01 AM
Hi Lexiss, It's not a second gen GS i have. I have a true aristo which is a first gen GS JZS147.
ilovegirls what do you mean use the LCA to get access how? take them off put on the brakes put them back on?
Lexiss_sc430 Feb 28, 2008 11:05 AM
Woops I'm sorry I didn’t read your profile and thought you had a 2nd gen.
zazzn Feb 28, 2008 11:16 AM
Ok form that thread i gather, they fit as i already knew but the LCA hits possibly? What is a RCA kit?
status.... Feb 28, 2008 03:52 PM
rca- roll center adjuster usually are used to help eliminate bumpsteer or binding in suspension from being too low. it looks like a spacer sorta but if you go into the 2gs section i see some using the rca so they dont have to shave anything on the ls brake upgrade
wonder if the 2gs one fits?
2JZ147 Feb 28, 2008 05:09 PM
Zazzn, if you can find a set of Supra TT calipers, they are a straight fit and require no grinding of anything.
However grinding and cutting of the backing plate is required though.
BKzSC400 Feb 29, 2008 09:28 AM
Originally Posted by zazzn (Post 3316680)
Hi All,
Ok my break problme has come back and my front stock calipers are sticking again and have warpped another rotor.
Thanks!
yo willneed to grind the corner of the caliper then you will need to grind the top of tierod cap. to make them fit, you will also need rims that clear the calipers like TT rims or sl4 spare tire. stock 16 will not clear! no spacers needed
twojayzee Mar 1, 2008 09:57 PM
Originally Posted by BKzSC400 (Post 3319881)
yo willneed to grind the corner of the caliper then you will need to grind the top of tierod cap....
Or get a RCA
zazzn Mar 3, 2008 12:56 AM
I would be in love if I could find TT calipers... I already have the discs that I've had for over 1 year and the pads along with the SS lines.
I ended up buying stock discs (cross drilled) because I need the car up running, I'm going to rebuild my stock caliper or take a look to find out why it's sticking.
sonyman Mar 4, 2008 01:52 PM
BRAKES
Again, say it with me. B R A K E S. Not B R E A K S.
LeXusFiTs Mar 4, 2008 03:29 PM
Originally Posted by sonyman (Post 3331159)
BRAKES
Hmmmm...I was wondering how many post would go by before someone said something...
