FS: Car Lift - Rotary 2 Post Lift w/ Hunter Alignment Runways
I have a Rotary 2 Post lift that has an H-Beam Hunter Alignment Runway setup on it. These are about $14,000 new, I can let this go for $SOLD...
Hunter Alignment Runway Includes: Recessed Front Turn Tables Flush Rear Slip Plates Internal Wiring for Hunter Alignement Controllers at front/rear Tilting Entry Ramps (QTY x2) Dual Piston Sliding Hydro Lift Jacks I'm sure anyone looking at this is familiar with these system, but the hydro jacks flip up horizontal so the lift can lay flat on the floor for loading the car, then the swivel down 90 degrees once the car is up in the air, and are direct lifting pistons, not a scissor jack like some other brands. Rotary 2 Post Lift Includes: Both Columns Rotary HydroPump and Reservoir All installation accessories and cables This was a fully working system when removed, all parts are included needed to re-assemble, it is currently taken apart ready for transport. Here is a good pic of what this looks like: http://www.garagegadgetsinc.com/imag...nment-lift.jpg And here is a pic of the actual lift for sale, before I disassembled it: https://lh3.googleusercontent.com/-C.../IMG951314.jpg And here are the cables and parts after disassembley, everything is here and well organized. https://lh5.googleusercontent.com/-q...google.com.jpg |
that is tempting....i wonder what shipping this would cost?
About a $1000. I can LTL freight it. But it would be a *****.
Still worth it if someone need an alignment rack. It is priced low because it's obviously a niche item and someone may have to travel a ways to load this up on a car trailer. I already have an alignment lift, but I had to buy this one in combination with the DSP600 3d alignment system as a package. I may consider selling the DSP600 as I think I may move to a DSP400 instead. |
yea shipping is pretty killer. thanks anyway though, i asked the boss and its a no go
got any pictures of the entire thing taken apart? and where in central va?
Originally Posted by neegroy
(Post 7457462)
I can get some pics. The columns are still sitting on a car trailer, It was taken apart about 7-8 weeks ago, The H-Beam runways are still bolted together as one peice, I had a tow truck move it together. It does come apart into 3 pieces though. But being a close trip I opted to tow it together because there is wiring inside the runways for the rear mounted alignment displays and controller. It can be taken apart if needed to be loaded on a car trailer to take back to NY if needed. The hydro pump and all accessories are stored inside the garage. I can load it onto the buyers trailer with the front end loader on my tractor. Everything would fit on a 16ft or better trailer. If the trailer is wide enough you might could load the h-beam in 1 piece. |
The alignment lift sold today.. Thanks fellas.
