Camry XV70 to ES conversion (body work)
Old Jun 10, 2024 | 02:45 AM
Entop's Avatar
Entop
3rd Gear
Default Camry XV70 to ES conversion (body work)
Dear Community,
I'd like to convert my 2018 Camry to ES shape.
Which body parts are just the same with installation points and which will need some frame adjustments?
Thanks in advance for your comments.
Old Jun 10, 2024 | 02:49 AM
Entop's Avatar
Entop
3rd Gear
This is what ChatGPT says:
Parts Requiring Adjustments:
  1. Front and Rear Bumpers: The bumpers are different and would need custom mounts or modifications to fit properly.
  2. Headlights and Taillights: These are differently shaped and sized, requiring custom fitting.
  3. Fenders and Hood: The exterior body panels differ significantly and would need adjustment for alignment and fitment.
  4. Grille and Emblems: Custom fitting is required for these parts as they have different mounting points.
  5. Side Mirrors and Trims: These parts have different designs and would need modifications to match the ES styling.
Old Jun 10, 2024 | 03:43 AM
ESh's Avatar
ESh
They are not just plug and play. It would cost you more money than to buy a new ES.
Old Jun 10, 2024 | 06:21 AM
ATL350's Avatar
ATL350
“Chat” is also leaving off additional body sealants for additional NVH reduction. I also believe from things I’ve read that there are some other structural reinforcements in the way of additional weld points for greater structural rigidity.
That doesn’t touch the interior which is a lot different, from seats to quality of materials.
Presumably this is an exercise in fantasy, for what would the point? As much as I like my ES, it’s not a Rolls. No one is going to be suddenly bowled over in this transition.
Old Jun 10, 2024 | 08:25 AM
bc6152's Avatar
bc6152
Hmmm. sounds like a Troll...
Old Jun 10, 2024 | 09:23 AM
Entop's Avatar
Entop
3rd Gear
My idea was to use flood-damaged ES body parts to enhance the exterior of a Camry.
Camry is after 100k miles and needs to replace front and rear bumpers. So I thought it could be a customization project. Thanks for your answer.
Old Jun 11, 2024 | 12:05 PM
losiglow's Avatar
losiglow
This reminds me of the guy on Acurazine that wanted to convert his 3G (2006) TL to all wheel drive. The best answer being "yes" it's possible, with a large amount of money - more than the car would cost and likely as much or more than buying a nice all wheel drive luxury car.
The price for parts, custom body work and probably a fair bit of mechanical work would easily exceed the cost of purchasing a 7G ES. Especially with the significant increases in auto work we've seen over the last few years. Not to mention time, hiccups and inevitable imperfections that will exist afterward.
Definitely not worth it.
Old Jun 11, 2024 | 05:32 PM
Jersey5974's Avatar
Jersey5974
Surprisingly you can relatively easily and cheaply convert the facade of a 6th gen to a 7th gen. Uncertain about Camry to ES though, you'll have to DYOR outside of this forum
Eurosport
Oct 12, 2010 09:48 AM
ES Boy
CL of Southern California
Oct 26, 2005 03:31 PM
StreetLexus
35
Aug 4, 2002 06:31 PM
