Beginner questions on the ES 250
Ultimately, bacause your ES250 weighs hundreds of pounds more than Camry, and has more sound insulation which encourages harder driving, your ES250’s motor will not be as bullet proof as Camry 2.5.
So I'd say if Toyota felt comfortable throwing the same engine in a 3,913 pound Crossover, the ES should be just fine with an additional 100 pounds of weight over the Camry.
The point is don't baby it, don't worry it, it's not your concern. As long as you do your part and maintain it, you'll be fine flooring it hot and heavy all day long. It's not for you to think about. It's just a car, drive it =)
ALL motion causes engine fatigue and wear.
The faster the motion, the greater the load, and the greater the duration - the greater the engine fatigues and wears.
Of course, poor lubrication will cause even greater wear.
Camry weighs between 3,300-3,600 lbs; ES weighs some 3,600-3,800 lbs. A Toyota Venza is about 40 lbs heavier etc.
Back in the 1990's, a typical Formula 1 racing 1.5 L V6 twin turbo would race at 2.5 bars, which is 2.5x atmospheric pressure - and the engine would last 2 races before it had to be rebuilt.
However, the car would qualify or run at short bursts of 5 bar, which is 5x atmospheric pressures, but only for a maximum of 5 minutes - because beyond 5 minutes would cause the motor to blow.
An ES generally won't last as long, not so much due to the extra weight, but the extra sound insulation tends to promote harder driving - without realizing it.
ES250's should be driven sedately, unless urgency arises.
For constant harder driving, best purchase ESh 2.5 L gasoline-electric hybrid, or 3.5 V6.
When ES250 and ES350 are both driven hard - back to back - the 2.5 L four cylcinder motor will never last as long as the 3.5 L V6 motor - regardless of how religioously you do your oil changes.
On the other hand, we wouldn't want to buy an ES250 used off a pensioner couple who only crawl 5 minutes away to the local shopping center once or twice a week either.
There would be so much carbon buildup etc.
This reminds me of a conversation I had with my Lexus contact. They basically steered me away from even test driving the ES250. They said the performance is underwhelming and that the benefit of the AWD is negated by the lethargic engine. That should give you an indication of the reality of how this car can be received even by Lexus personnel. Now don't expect this honest feedback from a typical dealer or sales rep. They want to move these cars just like any other.
But if the OP is satisfied with the car then that's what matters. I can only say I wouldn't have one.
I plan on doing the same thing in my ES once snow hits, with the exception of actually putting winter tires on! But from my understanding AWD really isn't necessary as long as you have good quality winter tires.
