Electronic dampeners? Costly repair
I was looking at the brochure and saw the ultra luxury has electronic dampeners included. That option makes me run away from the f sport and ultra luxury and look at the luxury package.
I know from research the air struts on the LS series run more than $800 a piece when they break. Im sure the electronic dampeners can't be too far off from that. Best to steer clear if you're keeping this car for 10+ years and drive a lot.
I do remember a Lincoln my family had, equipped with air suspension. Those bladders would need replacing way too often. That was back in the 80's though.
A lot of people do tend to avoid electronically adjustable shocks due to cost. I'd rather enjoy them for the time I own the vehicle and worry about maintenance later. Who knows how much a part will be in 10 years?
Either way, you can get the F Sport without electronic shocks. I don't think the Ultra Lux has the Adaptive Variable Suspension (electronic shocks), the website shows it as an F Sport only option. No reason to avoid these two models out of maintenance fears.
I opted for the FSport WITHOUT AVS for just that reason.
The ultra luxury has vertical active dampeners. So does the f sport. Active variable suspension (AVS) is an added option that adds more control and fine tuning of the suspension.
Are you referring to the Performance Dampers that are oriented horizontally in the front and rear of the vehicle? Those are not electronically controlled shocks like found in the Active Variable Suspension.
Included with the Ultra Luxury and F SPORT packages are performance dampers at the front and rear of the vehicle, which absorb energy from the chassis for improved handling stability and ride comfort while reducing noise from vibration:
The only downside I've found to this car after 4 months is that every other car I ride in feels like it rides rough and is too loud. Except my mom's '18 LS 500, that one is still smooth and quiet lol.
If they updated the ES in a few years with more powah I would probably trade in mine and finally have a keeper. I love fast sedans!
Now if you liked that Ultra Lux you test drove, go for it!!
The ES rides notably better with AVS, AVS is actually an incredible feature. I think its silly to avoid a feature that improves the car because it MIGHT break a decade down the road.
I have my doubts avs will ride better than the regular suspension.
I can see how it helps in cornering. But I feel it is used due to the 19" wheels and
rubberband tires on the f sport trim imo. You'd be better off using that money and getting a taller sidewall tire.
Electronic dampeners/ AVS are NOT the same thing as air struts. Totally different thing, and a failure of the electronic dampeners will not render the car underivable like an air suspension failure would.
