ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 7th Gen (2019-2025) (https://www.clublexus.com/forums/es-7th-gen-2019-2025-301/)
-   -   Dent Repair Feedback (https://www.clublexus.com/forums/es-7th-gen-2019-2025/1039900-dent-repair-feedback.html)
jcagame May 23, 2025 01:03 PM
I have a ES350 Ultra Luxury edition. There's a small dent/crease on the rear panel just above the back right passenger tire. I've gotten two estimates both from Lexus body shops. One for $2800 and the other for $9000. The second person claims that they have to take the sliding glass roof out the first one didn't mentioned that it had to be done. Any feedback back would be appreciated.
https://cimg9.ibsrv.net/gimg/www.clu...f83dd52c51.jpg
https://cimg1.ibsrv.net/gimg/www.clu...5fa4f32f11.jpg
Tootsall May 23, 2025 01:35 PM
Try one of those "paintless" or "dentless" repair places. That dent looks like it could be massaged out without removing anything but the tire and the fender liner. Check some Youtube videos on how they do it so you know what might be involved.
RofH May 23, 2025 01:37 PM
Why not go to a PDR (Paintless Dent Repair) Shop and see if they could take care of it or not — personally, it looks like they can from your pics.
I’ve seen work done by a PDR shop and you’d never know there was even a dent.
Plus, it costs way less than the quotes you got so I’d definitely see one before going the other route.
EDIT: Forgot to say to @jcagame — Welcome to CL and your first post :woot:
and Hahaha to @ESh’s post below 🤣 ⬇️
ESh May 23, 2025 02:22 PM
PDR, a couple of hundred bucks.
I would punch the $9000 guy.
jcagame May 23, 2025 04:54 PM
Thanks for the feedback It was a she and I was thinking that she is ridiculous!!!!!!
jcagame May 23, 2025 04:57 PM
Thanks the first person that I went to did mention a PDR shop. I will look into it. Much appreciated.
jcagame May 23, 2025 04:58 PM
Thanks for the feedback. I will look into it.
tfischer May 24, 2025 07:11 AM
I had a dent like that once in an SC. I asked at the dealership while I was there for service, and they said to come back on Tuesday (?), as that's when the dent repair guy visits. He did a great job, at a reasonable expense, and it was pretty convenient. Surely they only invite specialists like this to the premises who are qualified and experienced.
sc430sc Jun 12, 2025 04:23 PM
PDR quality varies. I would contact a Highline Dealership in your area and ask them who they recommend or use.
F3Woody Jun 13, 2025 05:36 AM
First, those quotes, wtf.
Second, why in the world would the sunroof glass need to be removed?
Now, I second the idea of contacting your dealer. They all have partnerships with a local dent repair/bodyshop. I had one much worse than yours and went this route. Kind of took the guessing & research off my plate, believing that partnership was an automatic vetting qualifier. In my case, it worked out great. Dealer handled the logistics, the repair was perfect, and the whole thing was under $1,000.
es250fsport Jun 13, 2025 06:11 AM
They forgot to tell you that engine needs to be removed as well to fix that dent to access the bolts that hold that panel.
Anyhow.
Screw the first two guys.
If the paint isn't peeling off, try reputable paintless dent repair guys. They do good job.
tfischer Jun 13, 2025 07:25 AM
If the ding did not crack the paint, then the dent repair guys can fix it pretty inexpensively. It's my understanding that if the paint is cracked, then the best repair requires the body shop. It's a little hard to tell from the photo if the paint is cracked or not, but could you elaborate a bit on the involvement of the sun roof?
E46CT Jun 13, 2025 08:47 AM
if that panel has access right behind the dent, then it should be fairly easy to knock out. if not, it still may be possible but may require more work (hours) either way cheaper than the 9k. update with pics if you get it fixed.
es250fsport Jul 23, 2025 07:32 AM
How did you go with this? Did you end up getting it fixed?
Lesley248 Jul 28, 2025 09:19 AM
"I know you came in for a haircut but we're also going to need for you to get naked too."
How much did the PDR end up costing and roughly how long did it take? always wondered
