Transmission lag
I noticed a problem with the transmission lag , during acceleration to merge from the ramp with fast traffic behind. It was scary and unbelievable as car with v6 engine and 300hp accelerated without engaging the transmission in drive “Normal mode” . It is my es350 2023. Is it a common problem? Or it needs a computer update? It has only 2000 miles on it.
any comments ASAP please? |
The transmission and shifting software in these cars only works well for very gentle and small accelerator inputs. Get a bit aggressive and the transmission does lag shifts and jerk shifts. There is no cure.
Originally Posted by CJS57
(Post 11581378)
...Get a bit aggressive and the transmission does lag shifts and jerk shifts. There is no cure.
(Post 11581378)
On my 2019 ES 350, when I floor the accelerator pedal I can't discern when the transmission shifts gears unless I watch the tachometer for big RPM changes indicating gear changes as the speed increases at a rapid rate. The same applies also with less aggressive accelerator inputs. Other than WAG speculation, I'm at a loss as to why some 8 speed transmissions have shifting issues and others don't. |
Originally Posted by docbhn9
(Post 11576487)
(Post 11576487)
My 2022 ES 350 continues to do it on a regular basis.
Quote: "On my 2019 ES 350, when I floor the accelerator pedal I can't discern when the transmission shifts gears"
Flooring it or Full throttle from stop or rolling is NOT when Jerk Shift happens. All our cars do that just fine. All our cars do Jerk Shift under certain other conditions. If you drive like Grandma going to Sunday school then you will never feel Jerk Shift. |
(Post 11616678)
Flooring it or Full throttle from stop or rolling is NOT when Jerk Shift happens. All our cars do that just fine. All our cars do Jerk Shift under certain other conditions. If you drive like Grandma going to Sunday school then you will never feel Jerk Shift. I really don't understand why they would make it so complicated, it should shift the same under the same load/throttle input conditions. |
(Post 11616678)
Originally Posted by artbuc
(Post 11616833)
Mine has a noticeable jerk/hesitation when accelerating hard from a rolling stop. Trans can not figure out if it wants to up or downshift.
Originally Posted by hotwings
(Post 11616841)
Did you notice this from when the car was brand new or did it develop over time?
Just put on Sport+ mode and you don't have the issue anymore, oh wait :D
(Post 11616841)
Nubie here. Just purchased my "22 IS350f AWD and have noticed on a couple of occasions throttle hesitation. In normal mode and at the start or moving slower (making a turn). This can get a driver in trouble if response to throttle is late. I'll have to try driving in Sport mode to see if that makes a difference.
| All times are GMT -7. The time now is 03:26 PM. |
